Question about Danby DDW1899WP Portable Dishwasher
Water softener I can't operate my new machine either, the red lights are on saying I need to add both softening salts and rinse agent. How can I by-pass this? Our water is very soft.
Marsena, I am at the point where I'm going to call a repairman. I'm very disappointed that I have a brand new appliance, and no means of having this issue handled. This is a great dishwasher otherwise, but I could not recommend it due to this problem.
Posted on Apr 13, 2014
Testimonial: "I contacted the business I bought the machine from who are sending a repairman out to rectify the problem. The lack of water softening salts should not prevent the machine from operating. If you unit is new contact the store you bought it from and have them repair it under the warranty and at no cost to you."
3 Suggested Answers
SOURCE: Water softener
Just a thought, I hope the lady did not use table salt :-)
Posted on Oct 29, 2008
  • 5 Answers
SOURCE: salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Posted on Jul 28, 2009
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I have a Bosch SHU66C02UC/14 dishwasher that leaves a white deposit on the dishes especially plastic drinking glasses. Suggestions are that it is not dispensing enough rinse agent. How can I adjust that...
This could simply be a detergent problem, but is most likely due to a low salt level in the water softener. The salt is used by the water-softener to prevent hard-water deposits which result in white stains on crockery and glasses. There are several things which can cause this:
1. There is no salt in the salt container.
2. The lid on the salt container isn't screwed on properly. (Don't overtighten though!)
3. Water softener is set too low
If you've checked and topped up the salt level and the lid is screwed on fully, then your water softener may be set too low. You should consult your user manual / installation instructions to change the setting.
The white deposits can also be caused by the rinse-agent being set too low. On your washer, the adjustment will be on a dial under the flap where you refill the rinse agent. I think it's numbered 1-5, so if it's set on 1, try number 3, if it's on 3, try 4 or 5. You may have to adjust a couple of times until you get it right.
If this doesn't solve the problem, try changing your detergent. Check the packaging and if your using phosphate-free detergent, try one containing phosphates. Phosphate-free is more eco-friendly though!
Oct 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
My dishwasher says that it needs salt what sort of salt and how much?
HOW MUCH SALT DO I NEED TO ADD?
shim.gifYour machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of 'dishwasher salt' use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Sep 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dishwashers
We have a fairly new Kenmore Elite front loading washing machine. We also have rather hard water here in Indiana. Problem is, water softeners do not seem to work. The manual says that the liquid water...
Hello, I would like to help with your dilemma. First, adding a Liquid or Powder Softening agent to the Wash or Rinse Cycle of a Washing Machine when using extremely Hard Water as the source is trying to treat the symptom and not fix the cause. These pre-packaged Softening agents are filled with Salts that attempt to mix with the Hard Water Minerals and Neutralize them so the soaps can saturate the water and supposedly clean the clothes more effectively. However, the Hard Water Minerals are still trapped in the water supply with these Salts because they are not removed. And, the manufacturers of these Salt Based Softening Agents have no idea of what level of Hardness (Calcium and Magnesium Carbonates) exist from City to City, State to State, or in private Well water supplies. So, if they provide 200 parts per million of Salts in their package, but the Water Hardness is 600 parts per million of Calcium and Magnesium Carbonates, there is no way the Salts will be effective. With "Traditional" Whole House Water Softening, the Water Treatment Appliance actually removes the Hard Water Minerals before the water is distributed to the entire home or business, then allowing the Washing Machine, Dishwasher, Water Heater, Showers, Bathtubs, and other water bearing appliances to perform their tasks as specified by their manufacturer. These Water Softeners typically attach to the main water line of the entire home or business, and virtually exchange equal amounts of Salt for equal amounts of Hardness regardless of the incoming hardness rating. Then, as the total capacity of the Softener becomes exhausted for the batch of water it has treated, the Control Valve automatically Regenerates the system with a new batch of Salt-Softened Water to use in the home or business. And, when you treat the water for the entire home, you reap the benefits of Protecting ALL of the Plumbing, Fixtures, Faucets, Valves, Appliances, and other household items from Scale and Hard Water Destruction. Visit our Web Site for more information: www.puresafe.com Thanks and Hope this helps. Victor Kernes
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Danby DDW1899WP Portable Dishwasher Logo
105 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
