Question about Champion 2000+ Household Juice Extractor
Spoon stuck in juicer - Champion 2000+ Household Juice Extractor
Can't release top
You need a man. When the machine jammed, it tightened the lid.
If you have an assistant, ask one to hold the bottom and wearing a pair of rubber gloves, try turning the top again with two hands. The gloves will help you grip.
Feb 28, 2016 | Omega Vert HD Machine VRT350 VRT 350...
I have model CL-003AP juicer and I cannot get the blade off for cleaning. I went to the instruction book, on line, and they say to lift and turn at the same time. This didn't work. What is your...
just take a dull butter knife or end of a spoon and gently pry it up in 3 spots or so as you go around. then when it is clean just pop it back on and push it into place ;-)
Jan 09, 2011 | Jack Lalanne Power Juicer 250 Watts
We have a power juicer pro and cannot get it apart. cant find the manuel. looking for a part to get the basket out? is there a picture of the tool so we know what we are looking for?
;-) just use a dull butter knife or end of spoon to gently pry it up in a few positions as you go around. i've owned one for 5 years and do it all the time ;-)
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
How do you open the blade on the jui3567cer
open the blade? you mean get it out for cleaning? just pop it out by putting a knife or back of a spoon under it and gently pry it up in a few places. works like a charm, been doing it for 5 yrs
Jan 03, 2011 | Jack Lalanne Power Juicer 250 Watts
Cannot twist off the filter basket of the breville JE 900 Juicer
I had the same problem. It must juat got a bit stuck - I gave it a really good twist anti-clockwise and it came unstuck and popped lose.
May 13, 2010 | Breville JE900 Juicer
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Nutrifaster N450 hex nut stuck
Your unit is a Nutrifaster not a Ruby juicer tray again their website of Nutrifaster in Seattle USA...good luck
Aug 30, 2008 | Nutrifaster Ruby 2000 Juicer
Jack Lalanne's Power Juicer Pusher Stuck
It will take two people to get the Lalanne Juicer pusher unstuck. We wrapped a sock inside a sock and put the top part of a hammer in the sock, then I lifted the large white part up while he hammered the pusher out. It took 6 hits and voila!
May 17, 2008 | Jack Lalanne Power Juicer (Stainless...
Champion 2000+ Household Juice Extractor Logo
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
