Question about HP Pavilion DV7-7128NR Laptop PC 2.50Gi5 8GB 750GB Beats Audio Webcam BluRay
Beats Audio Panel
When I click on the Beats Audio symbol the panel never opens. I've had this problem for two months.
  • HP Master
  • 3,320 Answers
I have an HP Pavilion 6000dv...specifically, it's a 6119us. I have no sound at all. I've checked the device manager, nothing is muted, I've gone through the troubleshooting program...still...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
I get video but no audio. am using win7 kindly help
You'll need to configure your audio settings properly. You've not mentioned your operating system so I can't guide you all the way but assuming its windows, click on the start button and look for audio settings or the control panel, then audio settings open them up, click on properties and make sure that the cd/dvd player is included in the volume settings.
Apr 17, 2011 | Computers & Internet
How to insert the rupee symbal in excel
Let me add with a brief details on how to download, how to install and how to type Indian Rupee Symbol:
Click here to download INR Rupee font, download this, extract the font file (once you open the zip file, you'll see a file name "Rupee"), copy it and paste it in the Fonts folder of the Control Panel of your computer.
Open a word processing program like Ms-word (in your case, Excel) and select the font as "Rupee" from the drop down lists, now press
on the keyboard.
You'll see the Rupee symbol :
Good luck.
Thanks for using FixYa.
Jul 21, 2010 | Microsoft Excel for PC
It cannot find hardware.
Not expert on this but......First make sure drivers are installed properly, Next connect to computer via USB. Next look to see if a popup on the taskbar says something like "Failed to connect etc." If so then open CONTROL PANEL.....Click on SYSTEM....Click on HRDWARE...Click on DEVICE MANAGER.......And then look for any YELLOW QUESTION MARK or MARKS......And / Or...Click on the USB Symbols to see if the BAD USB Shows its-self . Opening Any of these bad connection symbols will inform you if the DRIVER is installed properly, and will give you the options to UPGRADE or INSTALL etc.If this does not work the try the following:- Click on CONTROL PANEL. Click on Add-Remove Hardware and follow the on-screen instructions (While the device is plugged into the USB) All of the above simply is verifying that the drivers are or are not installed, but at least it will be a starting point.
Aug 06, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
My audio service is not enabled
First go to control panel - Sounds, Speech, and Audio Devices, then click on Sound and Audio Devices and make sure the volume is not muted.
If this is not the case click on Start - Right-click on My Computer - then Properties. click on the Hardware tab, then click device manager. When device manager opens, look for either one of the following symbols along the left hand side (!, ?, or x) The exclamation point and question mark will be yellow while the x will be red. If it is a red x, double click on that item and there is a drop-down list with the selections to enable or disable the device. Enable it. If one of the other two symbols are visible you will need to reinstall the driver. For that I will need the make and model of your computer.
Nov 09, 2008 | Computers & Internet
Yurning up volume
I'm going to make an assumption (assume=*** of u & me) that you are dealing with an Intel/Win machine.
If not, forget everything I wrote here.
It's helpful if you mention what your system and OS is.
You will need to click or double click on the speaker symbol on the task bar; if organized as common, it will be on the right.
On Win XP, a single click opens only the voulume control, double click gives you a detailed panel (different audio cards/chips look different since this is a software function) that allows you to control the level of different inputs or file types.
The presence of a speaker symbol on the escape button is kind of puzzling but may be a function of an extended keyboard that requires a manufacturer's device driver to be loaded when you boot.
That may not be loading.
(Some icons may require double clicks-)
If yes, then click on the Start menu, select Control Panel, then Sounds & Audio devices (or similar), this will show you if the sound is muted and let you select default volume level and tell you whose audio is installed.
If it looks OK, close the window and then click on the System icon, then Hardware, finally Device Manager.
Check the list for open folders that involve sound devices for any red 'X' on functions.
If you find one, then something hasn't been installed or turned on and since we don't know the exact system you have, it may require different methods of 'fixing' the problem and then you will need a friendly nerd nearby to help you.
May 27, 2008 | Toshiba Satellite R10-S802TD Tablet PC
HP Pavilion DV7-7128NR Laptop PC 2.50Gi5 8GB 750GB Beats Audio Webcam BluRay Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
