Question about Akai PT4298HD Rear Projection Television
Set wont turn on
When you turn on the set the light on the front turns green for maybe 30 seconds then turns red.; there is a red l.e.d on the card that the cable goes to that flashes when the power switch is cycled
  • 35 Answers
IF this is a dlp tv , the first thin you need to do is replace the lamp. J.D.W.
Posted on Jun 18, 2009
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Won't turn on. Green power light blinks for 30 seconds and then red lamp light blinks constantly
If the lamp light is lit, it is likely a bad lamp. If you remove the lamp from the set, you will either see shards of glass in the housing and/or a very cloudy reflector (it should look like a mirror). Be sure to use an original Sony lamp as the replacements are trouble makers. Please be sure to rate this solution. Thanks!
Oct 29, 2008 | Sony KDS-60A2000 60" HDTV
Playstation 3 red light on. but wont turn on ,goes green for a second then goes red again
the dreaded red light...it happened because your ps3 is on for long hours at a given time...give some rest and try again if red light goes green play for 3 hours let it cool down for 30 mins... if its dead then i'm sorry it is toast...take it to sony
Oct 07, 2008 | Video Game Consoles & Games
Akai PT4298HD Rear Projection Television Logo
113 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
