Question about Frigidaire Ovens
My oven is not maintaining temperature
I replaced the temperature probe however my oven is still not maintaining temperature.
    New Friend:
  • 4 Answers
Check the door gasket is in good condition.if the door is closing fully properly.check the ground level.
Posted on Apr 15, 2014
  • 74 Answers
SOURCE: Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Posted on Jan 18, 2006
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
  • 338 Answers
SOURCE: Set probe temperature
If i remember correctly i believe this is actually a wiring issue. you would need to turn the power off open the control panel. and look for a control board with the probe connection on it. there should be a tech sheet in the compartment to help you identify it however if it is the problem they would be purple wires on the connector that need to be reversed.
Posted on Nov 28, 2008
MARCLAVORIS
  • 110 Answers
SOURCE: Probe prevents oven from reaching desired temperature
if you had to sandpaper this probe, then this is yoru initial problem, do the right thing and replace the probe with a new probe
Okay
Posted on Aug 23, 2009
SOURCE: 5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Posted on Oct 23, 2009
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
Nov 06, 2010 | Ovens
F2 and a beeping noise just replaced the 350 degree sign on my oven as I was baking supper. What's up?
This is a fault code for the oven temperature sensor.
The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. If the resistance is bad, replacing the oven temperature sensor probe. This part can be purchased at www.appliancehelponline.com
Mar 23, 2010 | Kenmore Ovens
Oven doesn't heat up to desired temperatures, and if it does, it doesn't maintain that level
replace the thermostat temperature probe inside the oven, that is the cause of this problem alamost 100% of the time
Jun 27, 2009 | Ovens
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Ovens Logo
69 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
