Question about RCA HD44LPW62 Rear projection TV Lamp
Need a PC Board for HD44LPW62
I am trying to get a pc board for a rca tv. Model #HD44LPW62YX1
    Scholar:
  • 195 Answers
Try shopjimmy or Ebay.
Posted on May 08, 2014
  • 236 Answers
SOURCE: 56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Posted on Jan 17, 2007
  • 1030 Answers
SOURCE: HD RCA TV NEEDS REPAIR
Let see if i agree with the tech. first question what does the picture look like. Second in customer menu under setup do you have the "convergernce " option in the menu if not it might be a simple inexpensive repair known as fl231 fuse. if you have the option try autoconverging see how far it gets. does the picture bow in from the top and bottom. there are three possible cuircit boards that effect convergence. And it takes a technician sometimes to adjust... let me know and will continue to troubleshoot this down
Posted on Oct 29, 2008
ladywinn
  • 5138 Answers
SOURCE: Need a Power Supply / Deflection Board for a RCA D52W20BYX1 TV
Try UED www.ued.com or call 1-800-648-6657
Posted on Dec 22, 2008
freetek
  • 5568 Answers
SOURCE: need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Posted on Mar 01, 2009
  • 298 Answers
SOURCE: Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Posted on Apr 10, 2009
PC BOARD FOR TV MODEL#HD44LPW62YXI
not sure what board you require . there are several boards in this set and most are no longer available
Mar 26, 2014 | RCA HD52W59 HDTV Projection Television
44 inch RCA hd44lpw62yx1...sounds like fan is
It not the fan.These noise all way came from the colors wheel.Tries Tv Repair World.com,Ebay.com for the part.
Feb 06, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Feb 05, 2010 | RCA L32HD32D 32 in. LCD HDTV
My akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
Apr 08, 2009 | RCA Televison & Video
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
Need a CRT Board for my RCA Model 20F410T, PN 21301630
Here's a link to order the original RCA CRT Board Assembly for this model (20F410T) from a major parts distributor:
RCA 20F410T Replacement Part CRT Board Assembly
Feb 12, 2009 | RCA TruFlat 27F520T 27" TV
Want to know if color wheel can be repaired?
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD44LPW62 Rear projection TV Lamp Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
