Question about Printronix P7005 Matrix Printer
Can we check printronix p7005 shuttle assembly in printronix p7220
    Scholar:
  • 111 Answers
Yes if you reflash the unit in order to get it to work correctly. rcardenas@themrpsolution.com
Posted on Feb 04, 2015
  • 38 Answers
SOURCE: "Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Posted on Jul 17, 2008
jwr1914
  • 31 Answers
SOURCE: Print result p7005
You have something caught in the hammerbank cover. Sometimes a piece of lint, paper chad or some ribbon fabric will get hung in the holes and need to be cleaned out. Remove the ribbon, open the 'mask' as far as you can and look into the hammerbank area to find and remove the debris. Reload the ribbon and run a test print to see if the problem is solved. If not, the problem will usually be a hammer that is not retracting.
Posted on May 29, 2009
  • 12 Answers
SOURCE: printer
just go to add printer and install driver after finished wait for some more option.
Posted on May 17, 2010
apitjayakusu
SOURCE: driver printronix p7005
i have a printronix PSA3 P7005 but my driver is lost,please send me the driver. i want to re-install
Posted on Feb 06, 2012
  • 826 Answers
SOURCE: crtg missing instal new ribbon printronix p7005
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 28, 2012
Printing barcode using font 39
The printer can get out of "phase" and the print will look shaky. These instructions are for the P5000 but the phasing process has not changed.
http://themrpsolution.com/v//vspfiles/Tech%20Tips%20Q&A/Printronix/P5000_phasing.pdf
Jan 14, 2016 | Printronix P7220 Matrix Printer
Printronix p7005 reffil
do not use refill cartridge printing may be affected. use only new and exact cartdridge
Nov 08, 2013 | Printronix P7005 Matrix Printer
Bc sensor error Printronix P7005 Matrix Printer
upload firmware first otherwise change barcode sensor
Aug 27, 2013 | Printronix P7005 Matrix Printer
Printronix p4280 making noise
Depending on the specific circumstances, of course, the most likely culprit is the shuttle assembly. It could either be the motor in the assembly or the bearings in the shuttle assembly.
Put in hold mode. (Press Enable/Hold button)
Remove the shuttle cover assembly. (leave the screws in the cover itself when you remove it). On the middle-right side you will see a cover sensor -- you will need to fool this with a magnet.
Run a test print (Print Test button). (With the hood up/) Listen for the source of the noise. Is it the motor or the shuttle assembly bearings. (If the noise stops when you turn off test print and the motor is winding down then it is the shuttle assembly bearings.) Or is the noise elsewhere?
If elsewhere move around side to side to differentiate and locate the sound.
Here is a link to the part of the manual that describes replacing the shuttle assembly.
Please note that the motor itself is not really considered a separate field replaceable unit -- it is considered a part of the shuttle assembly. I only mentioned it separately above as part of the troubleshooting to consider the noise source. http://www.theprinterplace.com/printronix/P4280_Shuttle_Replacement.pdf
Jul 21, 2012 | Printronix P4280, P5005, P5008, P5009,...
Driver printronix p7005
Feb 01, 2011 | Printronix LineJetĀ® P7005 Printer
Print result p7005
Oct 19, 2008 | Printronix P7005 Matrix Printer
Printer
try to install generic text only driver
it will work
Jun 26, 2008 | Printronix P7005 Matrix Printer
Printronix P7005 Matrix Printer Logo
69 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
