Question about Garden
I have a Masport Quickcut ride on mower. It started cutting fine & then the engine died. when trying to start it again, there is a click & a beeping noise, but not catching. Blades are free of grass & there is petrol in it. Any ideas?
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 40 Answers
SOURCE: Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: Toro ride on mower won't start
Try replacing your spark plug. If that fails then go to the engine, cheak your carb, lines, and gas. cheak for gum in the engine/carb. If gummed then get carb cleaner and spray twice, wait 1 hour then try again. If my solution fails then you might need expert help. Good Luck!
Posted on May 24, 2009
darjr
  • 378 Answers
SOURCE: My engine runs fine, but
check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Masport mower
few things to check fuel lines are connected properly one may have gotton losse offf or pinched then make sure the blades are in off position some its a lever or a pull/push switch and battery may have gone dead or distributor to spark or plugs
Apr 13, 2014 | Garden
After running husquavarna riding mower 23hp mower starts backfiring and ends up quitting. mower will start back up but die out again as descibed.
I had the same issue and after trying everything I tokk the gas cap off and noticed there was negative pressure in the fuel tank when I broke the seal... I'm pretty sure the gas cap was just too tight, I threaded it back on but did not torque it down and the mower is running fine.
May 13, 2011 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Murray ride-on lawn mower model 155/107 (15.5 HP Briggs & Stratton engine). Engine starts o.k. but cuts out as soon as the hydraulic clutch is engaged via foot pedal. ie foot on clutch to start...
two possible problems. check power from safty switchs, put the lever down under the seat and rock the back tires back and forth until you here a click. then try again. a safty swith is giving you problems
Apr 25, 2011 | Garden
G'day, I have just used my masport 1000 presidential for the second time since purchase and it is not cutting the grass. It was cutting well initially until I emptied the catcher and made a height...
I have just found out that your mower has the Unique Quickcut blade system, with swingback feature to protect the crankshaft from damage should the
mower strike a solid object. If you can, you should check this and make sure this feature is operating correctly. It sounds like it has maybe malfunctioned, thus the cutting problem.
Feb 06, 2011 | Garden
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
