Question about HP rk281aaaba-01 - Wf1907 - Lcd Display - Tft - 19 - Widescree
Compaq monitor setup
Cannot turn off the power to the monitor, only by disconnecting the power cable. The power switch worked initially, but does nothing now. When I shut the computer, the monitor goes on sleep mode, but with power still on. I want to be able to switch power off completely, even while the computer is on. I don't have a manual for this monitor.
  • HP Master
  • 3,320 Answers
Posted on Apr 13, 2014
Testimonial: "Thanks, Mike, for your reply to my enquiry, and for sending me an electronic copy of the user manual for my HP (Compaq) WF 1907 Monitor. The manual helped a lot in setting up the monitor. However, my problem with the power switch seems to be just a matter of the switch becoming faulty, and is not something that can be rectified with information in the manual. Fortunately, the power switch has failed in the power-on position so I can use the monitor with no problem. If I want to turn it off completely, I can simply unplug the power cable from the electrical receptacle. Your assistance has been truly appreciated. Regards, David"
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
When i turn on computer only the power on light displays and nothing on the monitor. at first thought it was the mkonitor, but hookrd up to others and same prob. help please!
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
Sep 16, 2010 | Dell Inspiron 531s Desktop Computer
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
MONITOR WILL NOT WORK WHEN RE CONNECTED
You didn't state if you had a slot Video card , but if you do  check to see if it is down in the slot well, as you may have bumped it putting the hard driver in. Try taking it out and reinserting it, with the power off, of course.
Feb 13, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
HP rk281aaaba-01 - Wf1907 - Lcd Display - Tft - 19 - Widescree Logo
66 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
