Question about Music
Loose 1/4" input jack on a zoom super player 8080
    New Friend:
  • 151 Answers
You will have to open it. Then you will find that either the jack has come unsoldered from the board (solder it back) or you will have to replace it. If you are handy you can also get inside and bend the little metal spring that catches the tip back up so it gets pressure. Good Luck !
Posted on Apr 15, 2014
My zoom g1x next doesnt displaying anything after connecting adapter and input jack....why so????
Was it dI'd assume either the power supply itself is dead or a failed component in the initial connection point in the unit.
Oct 29, 2016 | Zoom Music
How to fix the input plug on a Crate GX-15 guitar amp.
If u can bend the 2 prongs back towards plug end it. Will work on prong rides on tip of it the second rides in between the to nylon rings on it if that doesn't work any radio shack carry it for about 1-2 dollars
Jan 02, 2015 | Crate Music
Marshall repair valvestate 8080
if it is C1 then it's the input capacitor from the instrument jack input, it's value is 10nF, as to it's type it could be 1 of three and I don't know without seeing it although all would work, from cheapest to most expensive, they are :- mylar, polyester or polyester film.
Good luck.
Aug 17, 2014 | Marshall Amplification Music
Appears that the 3.5MM input jack (for my ipod) is loose/broken. How to replace it?
to do that you'd actually have to disassemble the unit. ( start by removeing scews on the bottom ) and dropping out the pc boards that hold the jack or are in the way of the pcb with the jack on it. at which you'd just have to un-solder old jack and install replacement and reassemble and your done. you cann call american audio to find distributers of their parts.
Sep 05, 2011 | American Audio CK 800 MP3 CD PLAYERS SOUND...
How do i play a cd
Connect a CD player with SUITABLE cables to the TAPE INPUTS or to one of the stereo inputs. Note that a button selects whether the input comes from the RCA jacks or the 1/4 inch jacks for a couple of the inputs. You have to adjust the gain and trim controls to get the level you want. You didn't tell us what type CD player you have so we can give you anymore specific info.
Apr 15, 2011 | Behringer Europower Pmp5000 Powered Mixer...
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 | Music
My zoom 505 2 distortion pedal for my guitar will not function with batteries and the ac adapter slot is loose in the back, please help
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Mar 09, 2009 | Zoom Music
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
