Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell floor "spotbot" "not sucking" repair
How clear filters?
  • 556 Answers
SOURCE: User guide
You will need Adobe Reader to read/print these manuals
Use the following link and click Get Adobe Reader
http://www.adobe.com
There appear to be two models the user guides are in the right column -- be sure the models are right the model numbers 1200-a and 1200-B appear under specs
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=spotbot+1200
Posted on Dec 22, 2007
reddevil6
  • 1673 Answers
SOURCE: bissell 1699n proheat clear view problems
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Posted on Jan 17, 2008
  • 77 Answers
SOURCE: No Power on Bissell Spotbot
board likely not available, contact Bissell dealer.
Jim
Posted on Jul 28, 2008
jadyn08
  • 12 Answers
SOURCE: No manual
mnmpie, go to http://www.bissell.com/images/UserGuides/1200_805.pdf
Thanks.
Posted on Nov 15, 2008
  • 215 Answers
SOURCE: The Bissell cleanview II turns on, no sucktion
Check filters
Posted on Feb 18, 2010
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Just got a bissell proheat clearview force cleaner, we press the trigger, no water sucking action or shampoo release going on .. what's wrong?
By the Floor Cleaning setting knob and Tools for PreHeat setting knob, there's a red x inside a clear circle cap. Is it spinning at all? If not...twist the cap off and remove the red x. Under the red x there is a tiny little filter. This might be plugged. Pull it out and clean it. Put back in (this is all really easy).
See if it works now.
Dec 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Jim
Jul 27, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
