Question about Speed Queen Dryers
Drum not turning
I hear a buzzing noise when i turn the dryer on and the belt fell off i put it back on and still no movement from the drum
dididsaythat
  • 291 Answers
SOURCE: Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Posted on Sep 17, 2007
  • 16 Answers
SOURCE: Miele T 1515 electric dryer
Blower fan has fluff on stuck to it. It may even be disstorted. If you are really unlucky then it's done the blower fan motor bearings as well.
Posted on Feb 08, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint vtd00p tumble dryer giving
I assume you fitted the right value capacitor and connected it up correctly,if you have then slip the belt of the motor, and make sure it is free to turn with no resistance.
Try it without the belt on, if it runs o/k then problem is elsewhere, if it still does not run , then you could have faulty motor, and or timer. That is as much as I can help you.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
Maytag317
  • 1136 Answers
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Posted on Jun 01, 2009
  • 8 Answers
SOURCE: Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Posted on Dec 09, 2009
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
What to do on my dryer wen drum do not spend
If you hear a buzzing noise when its on then most likely its the motor went bad.. Or you can open up the back panel to see if it has a belt that turns the drum and check to see if the belt is slipping.
Dec 29, 2014 | Estate Dryers
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
When Itry to start my dry, it won't come on and I hear a noise(like an electrical relay when it stuck on)
the dryer drum belt is broken and there's a belt switch that shuts off the unit to prevent a fire from the drum not turning and the clothes overheating,the buzz is the motor start switch trying to start the dryer
Mar 08, 2011 | Frigidaire AEQ6700FS Dryer
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
My dryer makes a buzzing noise and will not turn on. I have to reach in and turn the drum, retry-go through this process several times before it "catches"and turns on iam wondering if it is the belt
Most likely it is the start winding on the motor. The buzz you are hearing is the thermal overload. You would have to replace the motor. Check pricing against a new machin. Sometimes the parts are less cost effective than a new dryer.
Dec 08, 2009 | LG DLE5932W Electric Dryer
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heats up but drum doesn't turn.
If the drum is very stiff to turn could be the drum bearings shot which would account for the broken belt, replace belt and it liable to break shortly after again. hover are known for there bad bearings and they cost a small fortune.
check it out have a look and see if there is nothing jaming the drum inside, i am certain your belt has gone and maybe down to the stiff drum making belt break, replace belt but bare in mind it may break again if the drum is too stiff.
choice is yours really. bearing kits cost more than 50 quid in general
Jul 10, 2009 | Hoover Dryers
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Dryers Logo
18 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
