Question about Insignia NS-39L240A13
Tv locked onto 1 channel and cannot change channels,also, will not turn on or off
Tv locked to 1 channel,sound ok, does not respond to any commands including on and off
  • Insignia Master
  • 3,320 Answers
  • 60 Answers
SOURCE: No digital channels
  1. Cable company sending something through the line. Also th insigna has a different tuner. Also can the insignia find the digital channels using an antenna?
Posted on Aug 23, 2009
Testimonial: "Thanks. I resolved it by removing a splitter from being in line with the cable itself."
SOURCE: Crown 32
I just restarted everything on my tv and it went away. I know that's not the simplest way to go about this situation, but it got rid of the subtitles! Hope this helps!
Posted on Jun 09, 2009
  • 280 Answers
SOURCE: cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Posted on May 01, 2009
barbu51
  • 566 Answers
SOURCE: i can't change the cable channels
Try the 991 code, press tv+ code set+991 then alternate between tv and power stop as soon as the tv respond then press enter , could take up to a 100 try since it goes thru all the codes. have fun
Posted on Nov 02, 2009
SOURCE: REMOTE SAMSUNG 00061J WAS WORKING WITH TV AND NOW
Go to your TV instuction booklet and locate code for samsung and reprogram remote.
Posted on Mar 15, 2010
Television model tp2784c101 what is the remote control menu/set up to keep channel so it doesn't automatically switch to different channel after 30 seconds; or how can I set it up to turn onto AV1 an
If the TV do not respond to remote control; to change channels, there are many possibilities. Check the infrared emission of the remote control first. Check it with fresh batteries. If the infrared sensor inside the TV is faulty, this kind of fault can happen. In other words, your TV need a through check up, which a normal user can't do with ease. Contact any service technician; or the authorized service centre. Electro help
Nov 18, 2014 | Philips Magnavox 27MS343S 27" TV
My Toshiba TV freezes when I try to change channels, how can I fix it?
Try to do a system reset and check if it fix the issue and check below video:
else if the TV is under it's warranty period you can always ask the seller / dealer to fix or replace if it can't be fixed.
Oct 02, 2017 | Televison & Video
Philips Flat TV locks up on one channel and won't change
hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Jul 25, 2009 | Philips Televison & Video
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Need help programing a RCA NITEglo remote cantrol
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player:
http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
Nov 14, 2008 | Televison & Video
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Television stays on one channel
You likely have bad solder connections in the tuner.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 12, 2007 | Sony KV-35V75 35" TV
TV changes channel changed before all numbers entered in remote
Possibly you're not putting the numbers in fast enough. If you are then there maybe a problem with the microprocessor responding too quickly to commands. I've never seen this problem before, but my TV will do the same thing if I don't get the numbers in fast enough. Stargazer
Mar 02, 2007 | Zenith C27V36 27" TV
Insignia NS-39L240A13 Logo
123 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
