Question about LG 37LG50 37 in. LCD HDTV
Tv turns on then off right away
I can turn on the TV but after 2 seconds it turns off. Very frustrating.
  • LG Master
  • 3,904 Answers
Power supply board needs to be replaced.
Posted on Apr 13, 2014
  • 4234 Answers
SOURCE: tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Posted on Jan 16, 2009
lightnbaby
  • 36 Answers
SOURCE: TV will turn on for 2-3 seconds and then turn off
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least! Mahalo!
Posted on Mar 15, 2009
SOURCE: when I turn on my lg lcd tv the picture goes out
Go to http://www.lcdparts.net/LCDTVInverter.aspx and purchase there improved aftermarket inverter boards as the OEM replacements will often soon fail again.
Posted on Nov 14, 2009
omaharox
  • 165 Answers
SOURCE: humming or squealing noise when tv is turned on (model 32LG30)
Be sure you have installed the stand scresw weather or not you are using the stand.
The back panel can vibrate without the screws.
Other sources of a hum are the coils on the power supply.
The power supply would have to be replaced to solve the issue.
Posted on Jan 20, 2010
spr1949
  • 1182 Answers
SOURCE: LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Posted on Aug 23, 2012
When I turn on the TV there is picture and sound for approx 2 seconds. Then the picture turns off, the sound is still there and the green on light changes and continually flashes orange.
Honestly, I forgot what it was, but I had to return my tv. It did the same thing. It was a Viore from Walmart. The replacement worked right away.
Dec 29, 2012 | Televison & Video
After turning on Samsung TV with Logitech 890, the tv does not right away. I hear the tv trying to turn on but it takes about 30 seconds to do so.emote
This may not be a remote control problem. try turning on the tv directly from the tv and see if it takes longer than normal to power on. Sounds like a problem with the tv.
Dec 08, 2010 | Logitech Harmony 890 LCD Remote Control
Need code for urc-3605 for bell express vu satillite
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 16, 2010 | One For All URC-3605 Remote Control
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
Device Codes
UNIVERSAL REMOTE CONTROL CODE LIST We have compiled a list (below) of codes for Universal Remote Controls. .... EXPRESSVU 464. FUJITSU 760 860. GE 265 863. GENERAL INSTRUMENTS ...
dogbytecomputer.com/codes.htm - 34k - Cached - Similar pages see if you code is in here.like my dishnet.remote,some no namebrand tv's just can't be controlled by other remotes
Nov 14, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
Black box in the center of screen
go to costumer menu and turn off closed caption function
Jun 22, 2007 | JVC AV-20220 TV
LG 37LG50 37 in. LCD HDTV Logo
71 people viewed this question
Computer Repairing
Computer Repairing
