Question about Sharp Office Equipment & Supplies
Trysing to find correct answer for tan^-1 Sharp
    Scholar:
    New Friend:
  • 74 Answers
Firstly make sure that you are in the right angle measurement (e.g. Degrees, Radians or Gradians.) To do this find the button with DRG written in orange above it then press 2nd F and this button and it will move you to the next type of measurement. Do this until you have the correct angle measurement.
Then press 2nd F tan (in orange above it you will see tan^-1) and type in the ratio and then press =.
And there you go.
Posted on Nov 26, 2014
5 Suggested Answers
SOURCE: tan cos etc with casio fx-83ES
set it up in correct rig mode, mode button (several times) until you get a window showing deg - rad - grad, choose deg (degree mode)
Posted on Dec 03, 2008
  • 8068 Answers
SOURCE: sin, cos, or tan, on casio wrong answer. another cac right answer
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Posted on Sep 17, 2009
  • 8068 Answers
SOURCE: I have a SHARP EL-501W calculator and i am getting
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Posted on Dec 07, 2009
  • 4 Answers
SOURCE: arctan function is not computing correct answers.
Perhaps you need to go to "Mode" and switch "Radian" to "Degree" or vice versa.
I'm not entirely sure because I don't follow any more math/science classes, but I remember there sometimes being a problem with those specific settings.
Posted on Mar 06, 2011
Why is my ti84 giving me wrong answers when I use trig functions?
Your right you should be in degree mode. However, my guess is you are somehow entering in cot wrong in your calc. Recall cot = 1/tan! In your graphing calculator enter: 35(1/tan(61) = 19.4.
Hope this helped!
Jul 09, 2014 | Texas Instruments TI-84 Plus Calculator
I do not know how to use the tan-1 when square roots are involved.
Use parentheses. If you do not have parentheses (doubtful), calculate first SQRT(2)/2 =
Result is displayed and saved in ANS memory. Now calculate the arc tan of ANS.
Apr 04, 2014 | Texas Instruments TI-30XA Calculator
Using the 2nd then tan-1 to find tan= the square root of 2 divided by two, I do not get the correct answer
The result depends on the angle unit you have selected for calculator. If your angle values should be in degrees, set angle unit to degree.
My tangent button is giving me wrong answers.
When you are handling trigonometric functions and their inverses, the results depend on the angle unit your calculator is configured for.
When angle is in degrees, tan (1/2)=8.726867791x10^(-3)
When angle is in radians, tan(0.5 radians)=0.5463024898
It seems that your angle unit on calculator is set to degrees, while it should be set to radians.
Jun 14, 2012 | Casio FX-300MS Calculator
Cot(x) = -0.6
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
Dec 06, 2011 | SoftMath Algebrator - Algebra Homework...
I have a SHARP EL-501W calculator and i am getting the wrong answers with the tan -1 function
Hope it helps.
Dec 07, 2009 | Sharp EL-501WBBL Calculator
I am getting the wrong answers with the tan -1 function
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Nov 06, 2009 | Texas Instruments TI-83 Plus Calculator
Tan cos etc with casio fx-83ES
Nov 19, 2008 | Casio fx-300ES Calculator
How to use the cot function
I don't have a Cot button but Cot x = 1/Tan x so enter
1/Tan 78 = 0.212556 etc if you have a fraction button you can write it that way too:
1 frac button Tan 78 = 0.212556 etc
Jun 16, 2008 | Sharp EL-531VB Calculator
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
