Question about Hammering
Solid red light bosch 11316 evs
Already changed brushes and new speed control
2 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: the methode of changing brushes of gsh 11 e bosch
AT THE UNDER PART OF THE DRILL HAVE 4 LONG SCREWS TAKE THEM OUT AND U WILL SEE THEM.
Posted on Aug 04, 2009
11316 evs solid red light
Could be it is drawing too much amperage - that is what this control detects.
How long has it been since it was torn down & serviced - that is a possibility.
The other is more costly, it is possible you have a bad armature causing this as well. Remove the bottom cover where you replaced the brushes and examine the armature - look for burnt / raised segments or burnt windings.
Let me know what you find.
Apr 13, 2014 | Bosch Hammering
Solid red light
1 sliding contact of the 4 pieces thats on the electricfield (stator) of the motor is broken.
SDS drill variable power
Ok about changing the brushes but have you searched if the place where the brushes are located allow the brushes to move forward freely or they are in a way were narrowed so that the brushes can only move for few millimeters?
Mar 06, 2014 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
Bosch 4000 table saw will not start. I changed the switch and still won't start, not even a sound. The saw is relatively new, and the outlet works. What should I try next?
A real Weakness of this saw is sawdust and debri entering the cooling ports of the motor causing intermittent contact of brushes which damages the motor speed control board ($40.00). Don't ever operate this saw with out a vacuum saw dust extraction system. Also when you replace the Speed control board also replace the Brushes ($6.00). It helps extend the operational life of the motor components to blow out the contaminants regularly with compressed air through the motor cooling ports (turn off saw first).
You can bypass the speed control board (if you want to disable this wonderful engineering feature by attaching black and white power wires directly to the black and white wires to motor.
Feb 22, 2010 | Bosch 4000 - 07 Electric Table Saws
I have a BOSCH 4000 table saw which spins very slow. I opened the motor took out the field to examine. When I tried to reassemble it, I faced some problem. There are two wires from field, one connects to...
There is 4 wires from the field, 2 reds a white and a black. the reds have spade connectors on them, they go to the brush holders. The white goes to the white on the speed controler and the black goes to the black on the speed controller. There is one wire from the speed control that goes on to one of the brush leads, there is a small adapter that allows both wires to be connected. If the motor spins very slow then the field is faulty and needs replaced.
Hope this helps
Feb 11, 2010 | Bosch 4000 - 07 Electric Table Saws
What is EV on the menu
Hi cute_chic24,
EV is Exposure value refers to the amount of light for a given exposure. It is denoted as a single number. Its value is subsequently used to calculate the correct combination of shutter speed and aperture at a given ISO speed of the sensor.
Starting point is a shutter speed of 1 second at f1, which is denoted as EV 0. Further up the scale a single exposure of EV13 could be ISO 100, f8 - 1/125s, or f11 - 1/60s.
It doesn't make any difference which combination you choose, as all variations at the same EV will ensure a correct exposure. Remember though, you are always balancing camera or subject movement against depth of field. This is because a change in aperture will require a change in shutter speed for an equal amount of light to reach the sensor or CCD. If you set the shutter speed one stop slower and aperture one stop smaller, exposure doesn't change, but you increase depth of field slightly and the possibility of blur.
ERNZ
Feb 03, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
Bosch 1617 EVS router will not start.
It sounds like either the switch is going bad, or the brushes have worn out. It's hard to say, not knowing how many hours of use you have on the machine. You've already pulled the cover. Take a look at the length of the brushes and see if they're a candidate for replacement. If not, it's not much farther to go to replace the switch.
The only other likely cause I can imagine is that the power cord itself has been bent into the same shape so many times from rolling it up around the router that is has a short and makes intermittent contact. But you say you have checked this and the fault is not with the cord.
You might try spinning the motor armature part of a revolution by hand, so it comes to rest in a different spot, and trying the switch.
These switches do go bad, and that is usually the culprit. The history of the switch seems to indicate it was behaving erratically before it failed, and with new ones costing only about $5.00, I'd invest in a new one, install it yourself, and save yourself the cost of a service fee.
You can acquire parts here, among many others, if you choose to follow that course: http://www.ereplacementparts.com/bosch-1617evs-0601617739-router-parts-c-128_1119_3070.html
If you do order parts online, try to confirm you've found the correct part by including the Bosch 10 digit tool product number in your search.
I hope this helps to lead you toward a swift solution. Best wishes!
Mar 18, 2009 | Bosch 1617EVS Router
Hammering Logo
76 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
