Question about Epson Office Equipment & Supplies
Scanner error 02
My xp-305 kept coming up with the paper blockage message no paper in it .removed top section (scanner) off to gain access sorted fault then when put back together keep getting e-02 scanner error help please
  • Epson Master
  • 783 Answers
Go To Below official Epson Printer Page For Your problem, Product Status Messages Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Posted on May 30, 2014
SOURCE: My printer is eating my paper
Hi
I had exactly the same problem and had to stop my flatmate trashing the thing! Try buying the cheapest, nastiest supermarket printer paper you can find! Works great in mine...
cas
Posted on Jan 26, 2008
geemarie
  • 876 Answers
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
Posted on Aug 15, 2008
Astinsan
  • 87 Answers
SOURCE: top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Posted on Nov 22, 2008
SOURCE: Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
Tengo el VISTA, Al tratar de escanear diapositivas con un reflecta x2-scan, cuyo sofwar he instalado, me da exactamente el mensaje que reseñan "Can not find camera. Please connect Omnivision SuperCam".
¿Como puedo activar dicho dispositivo?
Posted on Aug 25, 2009
SOURCE: error code 3528 keeps coming up,telling me to
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Posted on Jan 18, 2011
Epson printer xp 305 printer error E-01
This Epson Printer error E-01 occurs in the Epson Service Manual which indicates a type of fatal error. It simply signifies that the printer is incapable to finish the self-test process. When users are trying to power ON the printer it begins to check for all systems. If it is found that it is unable to finish the self test process then, the printer will come up with an error message as mentioned above. Follow these steps to resolve Error E-01.
Steps to Resolve Error E-01:
Step 1: Turn on/off the printer power button
  • Turn the power off. Wait for a while then turn on it again.
Step 2: Managing the lock of the printer
  • Store transportation lock carefully.
Step 3: Managing the CD tray
  • Press the CD Tray button to retract the tray to its original storage position. Be careful never to push or pull the CD tray into the wrong position. Turn off the Epson Printer and make sure that there is no paper left which may lead to paper jam issue inside the unit.
Step 4: Checking the printer cartridge
  • If the printer is installed with the CISS then, make sure that its carriage is easily movable towards left and right side.
  • The printer's upper scanner part should be closed tightly.
Step 5: Perform a check-up process.
  • Install original Epson ink cartridges and then run the printer.
Step 6: Access the cartridge
  • Access the cartridge loading area while the printer is in off-mode and then, move the carriage right away from the stop. Carefully disassemble the printer and then, clean all its optical sensors, paper feed sensors, encoder strip as well as disc encoder.
Contact Epson Printer Support Number if you have any issues in printer.
Apr 12, 2014 | Epson Stylus RX580 InkJet Photo Printer
Clean lenz of c351
Cleaning the scanner section is very dangerous do to the fact that if you remove the wrong screws for the Charged Couple Device (CCD) the black device on the right side you can screw up the images!!!!. as for the mirrors on the left yes you can clean them use really clean paper or light cloth. to remove the scanner glass requires the top front and right side cover removed. Gentle pull out the scanner section. DO NOT PUT YOUR Fingers on the Lamp!!!! Oils from you hand can mess with it exposure abilities when it comes on to see the original. Watch the cables DO NOT WANT them to unwind. Watch out that unfinished aluminum is SHARP will slice up your hands.
Jan 15, 2014 | Konica Minolta magicolor 2400 Laser...
The printer is showing a paper jam even when no paper is stuck. The help instructions are not very useful. How do I get rid of the paper jam message and go back to normal use Thank you
Quite often these sort of problems are caused by the paper feed roller(s) becoming too smooth to pick up the paper. Gain access to the roller and, using a very fine emery paper, about 600 grit and gently rub it all the way round and along to give it some grip. When I say "gently", I do mean gently.
Oct 30, 2013 | Toshiba EStudio 223 Copiers
It is saying paper james in the printer, open the scanner unit and remove paper, however there is no paper, have turned off the machine and still comes up with the same problem
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 25, 2010 | Office Equipment & Supplies
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
The ready/error indicator is red... the error message with (ID:3009) keeps coming up "paper exixts in scanner yet. please open the door and remove the paper." and there is no paper in the scanner and i...
hi....
I have this same problem every time.....first unplug it.....I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble).
Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate.
Jul 04, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Out of paper message, won't feed paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.
May 20, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
339 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
