Question about Canon PIXMA MP620 All-In-One InkJet Printer
Error u052 on canon mg5140 - Canon PIXMA MP620 All-In-One InkJet Printer
4 Suggested Answers
  • 159 Answers
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
x404x
  • 51 Answers
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
http://www.buzzillions.com/review/canon-pixma-mp610-multifunction-photo-printer-review-2458903?prRo=0&reviewSortBy=mostHelpfulFirst&prRpp=1
you wont like what you find. lol .
apparently if you call cannon support they going to tell you its a U052 is a temperature sensor error. and not the print head error. someone musta did some bad programming. lol
try returning the cartridge if its not a canon specific cartridge - and get replacement - try that - but i doubt its going to work - i would call about a new one (print head that is - they will also apparently send you a new print head.) as i have read up on
hope this helped x404x
Posted on Mar 01, 2010
Testimonial: "Thanks for your quick response - I thought there was a resetting tool available so I can at least remove the message and get printer going."
SOURCE: Canon Pixma MP600 - Error Message U052 ... incorrect print head
my 1 yr old MX855 got the U052 message after I replaced 2 cartridges.
Called Canon Support. They said this has nothing to do with the cartridges.
Printhead is damaged or not set right. He walked me through resetting it.Open lid, remove cartridges, lift gray lever and pop it open to the top. Remove black plastic box which holds cartridges. Inspect bottom print head. If shiny and clean, re-insert it. Lower grey lever which is spring loaded. When it snaps down it holds printhead in place. This worked for me.
Posted on Sep 14, 2012
What is the corrective action for error U052?
Search "u052 error canon" and choose the hits to open.
Jul 08, 2015 | Canon MG5350 Wireless PIXMA Inkjet...
How to fix u052?
Error U052 = Please check that print head contact pins of the carriage are not bent.
Or else you may need to replace
- Print head
- Carriage Unit
Jun 29, 2014 | Canon MG5150 AllInOne Printer
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
Canon pixma mp630 error u052
FYI, Canon inkjet printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Mar 29, 2012 | Canon PIXMA Office Equipment & Supplies
Canon MP660 U052 Error
Remove and reinstall your Printer Cartridges. Else, you will need to take your printer to a Canon Service Center to have them replace your faulty Print Head / Temperature Sensor that is causing the U052 Error.
Oct 24, 2011 | Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit?
May 24, 2011 | Canon Pixma MG5220 InkJet Printer
Error message u052
That is a printhead error, sounds like you will need that new printhead.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Reseat the Print Cartridge. Go to Canon site (see below) and search for U052 error. I followed the directions with pictures and the error went away. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Apr 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
Canon PIXMA MP620 All-In-One InkJet Printer Logo
144 people viewed this question
old marine
old marine
