Question about Canon imageCLASS D780 All-In-One Laser Printer
Priner wont feed
I put the paper in try to copy of fax and it rolls but stops? I just read someone else comments and checked the spring and it is in tact? I am not sure how to fix the feeder?
    Problem Solver:
  • 5 Answers
I will recommend that you put your printer power off for 2 seconds and remove the tray again and reset it back accordingly and put the power on again and try to fax. Make sure you turn. Let me know how it went.
Posted on Jun 18, 2009
    President:
  • 828 Answers
You cannot fix the feeder, just call an assistance you repair your printer, call a technician... that's all i say to you...
My fax machine keeps jaming on the right side in the paper tray, what causese this
When it jams, does the paper get bent or crinkled? If so, there is probably something lodged in there causing the paper to stop. Could be a paperclip or staple, or maybe another piece of paper.
If there is nothing blocking the paper and it just stops feeding on one side, you may have a tension problem -- springs might be getting old and not pushing rollers together tight enough to feed the paper. If you can take the machine apart, try switching the springs around to see if that makes a difference.
May 26, 2010 | Brother IntelliFax-4100e Fax
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
Copying on the 930
replace your roll, if you havent use for quite some time, chances are this could be overexposed
Aug 30, 2008 | Brother FAX 930 All-In-One Thermal Printer
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper not feeding properly
1. Clean the rolllers first.
2, Then on the upper half of the scanner, look for a pad with small leaf springs on it. That pad can be worn or one of the springs bent down. Look into there with a flashlight and see what is dragging on the paper.
Look carefully on the top and bottom half of the scanner, you have some type of partial obstruction.
Feb 25, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
How to feed paper into the Sharp fax UX-108?
first the paper is rolled over the top and then roll it slowly under untill you can pull it out by hand. At this point you can close it and it will automatically start to feed.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
How to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Canon imageCLASS D780 All-In-One Laser Printer Logo
82 people viewed this question
old marine
old marine
