Question about Toshiba Office Equipment & Supplies
08 TEST MODE TOSHIBA E STUDIO 281 - Toshiba Office Equipment & Supplies
SOURCE: Toshiba e-studio 207
Before you turn the printer on press and hold 1 3 and * and then turn the printer on. you will hear a few beeps when the beeps stop you can release the buttons. this resets the printer.
Posted on Dec 05, 2008
  • 126 Answers
SOURCE: Studio 35 F10 error
Error F-10 = HDD problem
F-10 fix; do 08-690 which will probably get the machine running again unless the HD is totally fried. You can replace the hard drive with any hd as long as the firmware version is 17 or higher. If you take off the inner tray you can see it buried in the middle under a plate and a board. Make sure that the HDD is set to 'master' when replacing.
Posted on Jan 24, 2009
EmmettPinger
  • 63 Answers
SOURCE: I HAVE A E STUDIO
What you have is a fusing problem. The problem of the toner not sticking to the paper has to do with the hot rollers. There are three problems that you may have the first is the unit is not heating up to correct temp. next is the pressure between the hot and pressure rollers is not to spec. or the roller is damaged or wore out . good luck
Posted on May 01, 2009
  • 136 Answers
SOURCE: after switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Posted on Jan 20, 2010
    muntejaya
    • 10421 Answers
    SOURCE: I have a printer Toshiba
    Your printer is in test mode. Please reset the printer and re try to print
    Posted on Jan 05, 2011
    Toshiba 2540c hangs on test mode D. When I enter codes nothing happens. How can I fix this?
    There are new codes and old codes..depend on the firmware of the machine.....check your firmware and put codes that are working with that firmware
    Mar 01, 2016 | Toshiba e-Studio 2540C Multifunction Color...
    Toshiba 281 c fax
    How do time for periodi mantenance?
    Nov 12, 2011 | Toshiba E-studio 281c Copier
    How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
    You can use the Toshiba e-studio 160/200 service manual for this machine,
    Enter 08 Service mode and:
    check these addresses
    340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
    250 is 33,000 copies. If set to 0:Nothing displays.
    673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
    SRU: Service Replaceable Unit.
    CRU: Customer Replaceable Unit.
    Good Luck
    Jun 27, 2011 | Office Equipment & Supplies
    Screen appears error with thermistor,what i have to do?
    switch hold down 08 while holding 08 down swich on machine wait until test mode starts on the number pad put in 400 and press start input 0 and set switch off wait 30 seconds and swich if error code c440 is back you have to replace thermistors and thermofuse
    Mar 06, 2011 | Toshiba e-studio 455 Copier
    How do I clean a hard drive in a Toshiba Studio650
    08-690 subcode 2 switch off machine hold down0+8 keys switch on in test mode input 690 start input 2 and enter hdd clean
    Feb 21, 2011 | Toshiba E-STUDIO 650 Copier
    ı want to know how to solve ? Toshıba e-studıo 4511 error code:CEA0 CEF0
    [CEA0] = Revolver home position detection abnormality
    Need to check the home position sensor on transfer unit, perform input test. ( 03-[FAX]ON/[2]/[C])
    [CEF0] = Revolver motor abnormality
    Perform output test to check the revolver motor. ( 03-450 )
    If still cannot solve, try replace LGC board.
    Oct 08, 2010 | Toshiba E-Studio 3511 Color Copier
    Toshiba e-280 shows F-120 error code, i dint find this error in my service hand book. any suggestion to overcome this problum.
    [F120] Database abnormality
    What you can try to do is go into (08) mode by holding the 0 and 8 keys while turning on the copier. Once it comes into test mode key in 684, this rebuilds the databases. If this doesn't fix it go into (08) mode again and key in 690 and press start, key in 2 and just hit start again. This formats the HDD and hopefully the copier will work after that. If not you will likely have to replace the HDD.
    Note: When you format the HDD it clears out only information such as address book and templates.
    Sep 10, 2010 | Toshiba e-STUDIO 282 Black and White...
    I dont have the admin password toshiba e-studio 202L
    202L HOW TO RESET ADMIN PASSWORD IS HOLD 08
    TURN ON MACHINE YOU WILL BE IN TEST MODE THEN
    PRESS 263 CLEAR OLD PASSWORD AND ENTER DEFAULT PASSWORD 123456. ENTER TUNRM OFF MACHINE THEN ON.
    Jan 05, 2010 | Toshiba Office Equipment & Supplies
    How to do toshiba studio 200 drum maintenance?
    clear 08-673 to 0 (08 means setting mode : hold 0
    Nov 12, 2009 | Toshiba Office Equipment & Supplies
    113 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
