How to use olympus ws 811
My recorder memory was full so I transferred the files onto my computer and then erased them, it is now completely empty but keeps flashing "Memory Full". I can't use it at all. What can I do?
  • 16 Answers
SOURCE: Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Posted on Jun 17, 2008
SOURCE: I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Posted on Jul 16, 2008
SOURCE: WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Posted on Nov 29, 2008
  • 919 Answers
SOURCE: how do i REALLY erase on my olympus ws-300m?
Suggestion is to format the device to remove all unwanted data permanently.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens
2 Press the + or – button to chooseSubmenu and then + button to “Format”.
3 Press the OK button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Posted on Dec 22, 2008
SOURCE: Memory Full
Go to the menu and go to the format option and press enter. This worked for me :). Make sure you have everything backed up.
Posted on Jun 22, 2009
It says "Memory Full" but
If you are sure you have erased all files in all folders then it would not do any harm to run FORMAT from the menu.
This may well clear your "Memory Full" message and get your device working again.
Hope this helps.
Sep 10, 2011 | Olympus WS-110 Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Won't record, looks empty, but says it's almost full
Connect the recorder to your mac and empty the trashbin
Jun 20, 2009 | Olympus WS-300M Digital Voice Recorder
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Olympus W_S 100 can't record/erase
the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer
Oct 12, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
PLAY button.
PLAY button.
Sep 20, 2008 | Olympus WS-200S
Try this:
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Ws 200s deleted files but still full
PLAY button.
PLAY button.
Mar 20, 2008 | Olympus WS-200S
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
29 people viewed this question
 Grubhead
Grubhead
