Pioneer dv 333 dvd player HOW TO CONNECT TO PC ?please do reply @ raz1932000@gmail.com
I need to know how to connect my pioneer home theatre system mentioned above to my HP AIO(All In One)pc.
    Problem Solver:
  • 10 Answers
If your PC has an HDMI in/out you should be able to connect it very easily. If you are already using the "out" to go to a monitor, then you may need to get a switcher. Alternatively, depending on the connectors available on the receiver on your Pioneer and the AIO computer, you may be able to use other cable.
Posted on Apr 13, 2014
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
  • 84 Answers
SOURCE: Philips Home theatre system HTS3000
try to clean the lens of your player with the cd lens cleaner available in the computer store or appliance store.
Posted on Jul 21, 2008
SOURCE: How do I connect my laptop to my home theatre system?
The best idea would be to get an audio interface, providing that your home theatre has an IN such as left and right phono. hese can be found for around 60 GBP. A chaeper alternative would be to buy and adapter which splits headphone to phono although an audio interface would allow you to send sound from you theatre in to your laptop as well.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
chipsandnuts
  • 70 Answers
SOURCE: dvd home theatre system
Samsung HTS units have a heat protection mechanism.
Basically the unit shuts itself off to avoid overheating and further damage.
Reasons for this:
Unit's internal cooling fan may need to be replaced
OR
The unit may be sitting on another device (cable box, etc)
OR
The unit may not have adequate space at the back of it.
You can try:
Letting the unit stand alone. No device should be below it. Make sure it has adeuate space on its rear.
If those don't work the unit needs repair.
Hope this helps!
Posted on Jun 25, 2009
I have F&D home theatre.i have to connected it to my pc but it's not working
They probably said you must connect the sound card of your PC to the F&D home theatre.
PC----------------F&D------------F&D loudspeakers
Sound out------Sound in------PC sound out
The home theater just amplifies and distributes input sound to the speakers.
Dec 02, 2017 | Audio Players & Recorders
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
How do i hook up my pioneer dv 333 dvd player
hook up to your receiver or ampli? your DV has got dscrete audio channel connections, now check first your receiver or amp if it has got that same discrete connections. but the simpliets connectgion is just uise your right/left channels. color red/white audio out of your DV. then connect to your receiver/amp DV input. or your DV should also have an fiber optical out (single link only to your amp) if it has got an option for optical. then connect your DV video out to your TV or through your receiver if it has got a video input function.
May 03, 2008 | Televison & Video
Pioneer dv-400v via ethernet?
No, it is not possible to connect a personal computer to the DVD player.
http://www.manualnguide.com/dl/4791/ Page 31
Apr 08, 2008 | Televison & Video
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
207 people viewed this question
 Grubhead
Grubhead
