Question about Nikon D200 Digital Camera
Partial black in frame
My D200 has had an intermittent issue the past few days. The left quarter of the frame is black. It isn't a sharp line, but a gradient that goes image to black over the left quarter or so.
When I changed my settings, it fixed the problem. I was shooting at 1/250 at f/25. When I sped up the shutter and opened up the aperture, it solved the issue.
    Sergeant:
  • 321 Answers
AE + 0.0
iso 200
Posted on Jun 18, 2009
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Nikon D200 images not sharp
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Apr 13, 2009 | Nikon D200 Digital Camera
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Screen turns black after 5-10 minutes
check the power options in os from control panel whether the option "turn off the monitor" is in "after 5 mins" if so make it never....
if not check in bios power and frequency control properties...
Feb 06, 2008 | Sharp ll-m17w1u 17" Flat Panel LCD Monitor
Nikon D200 Digital Camera Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
