Question about Lenovo Computers & Internet
Using technika LCD19-910 as a computer monitor
How do connect the sound
    Sergeant:
  • 231 Answers
Depend on how you are connecting to it. If using a VGA cable and the monitor has built in speakers, there should be an audio jack which will require a cable from your audio out (headphone) from Laptop to the monitor (male to male connection).
If using HDMI, you may have to enable the sound - check the video below.
Posted on Apr 13, 2014
How do i connect my soundbar to my technika lcd 32-244 tv
There should be a output on the TV. Hook the sound bar up, set the TV up to use external sound and use the sound bar remote untill you sync it to a different remote. Give it a try!!!!
May 22, 2014 | Televison & Video
Technika tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Televison & Video
No sound
What connection type are you using? Make sure that type of connection is selected on the monitor.
What sound output have you chosen in Windows mixer. Make sue it is the one you want.
What brand and model of monitor and computer are you using?
Apr 06, 2014 | Samsung Computers & Internet
How can i use my 32 inch technika LCD as a computer monitor
easily. grab yourself a dvi connection and hook it up to your computer. if your tv doesnt have a dvi connection then this is not possible.
Feb 17, 2010 | Televison & Video
No sound on Technika HD TV when using my Xbox using HDTV cable
i cant get soun when playin my xbox 360 on my technika tv. how do i obtain sound?
cheers
Jan 12, 2010 | Microsoft Xbox 360 Console
How to connect Technika 5.1 Speaker System to tv
How did you connect it up to the TV? I am stuck even connecting mine yet alone getting sound :S
Nov 27, 2009 | Audio Players & Recorders
Technika LCD37-907 no sound from hdmi ports
Are you using the Audio out RCA connectors at the back of the set. Are you watching/listening from source connected on HDMI input?
I have Technika LCDDVD19-918 TV. The manual specifically states "Audio Line Outs - Note: line out feature cannot be used while in HDMI source, us SPDIF instead". You could try using the headphone jack for audio out.
SteveC.
Oct 18, 2008 | Televison & Video
I am connecting a Technika 1031 to a LG 19LS4D using a good quality scart. I get sound but no picture. Connecting via the Y, Pb/Cb and Pr/Cr ports does nothing. Am I doing something wrong?
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Mar 18, 2008 | Televison & Video
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Computers & Internet Logo
29 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
