Question about KitchenAid KGST307 Gas Kitchen Range
Pf light comes on shortly after unit is plugged in
Keyboard comes on shortly then pf light comes on stove top burners and strikers work clock functions but cannot be set
5 Suggested Answers
  • 93 Answers
SOURCE: setting the clock
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Posted on Jul 24, 2008
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
  • 189 Answers
SOURCE: I tried to change the light bulb in the oven,
Hello- Glass bulbs don't make very good handles, do they? Find a good tech to check wiring behind bulb socket. May have burned a connection, and or grounded a wire somewhere. Electric ranges have two 110v circuits that work in combination. One is out. Let me know if info helps- have more if needed- Thanks- ED
Posted on Mar 04, 2010
jumptrout51
  • 3361 Answers
SOURCE: We have a Kitchenaid gas
Check your circuit breakers and or ground fault circuit interrupters.GFI.
You have no power to the range.
Posted on Aug 10, 2011
Stove top works oven does not have pf display
PF is power failed
power shut off .
should be able to hit cancel or enter button
then set your clock should function after that .
If not we need more info Like model # off appliance
Brand name . you may need a main board
Jul 02, 2015 | Ovens
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Whirlpool Cooktop will not reset
Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
Dec 27, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Jul 13, 2008 | Whirlpool GS460 Gas Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
KitchenAid KGST307 Gas Kitchen Range Logo
20 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
