Question about Compaq Computers & Internet
Mxamize screen fit screen to laptop
    New Friend:
    Problem Solver:
  • 11 Answers
If you type in fit screen and the model make and number into Youtube provided you have access to another computer of course there will usually be a walk through video explaining how to fit. Every model an make can be different .
Posted on Apr 13, 2014
How do I adjust tv screen size to fit laptop? lap top projection is to large for operating properly. to big.
Assuming you have a flat screen 16x9 TV, make sure it is set to screen fit so that there is minimal overscan. The button should be called pic size or aspect ratio. Also set your laptop to the same resolution as your TV or as close as possible to a supported resolution.
Feb 02, 2018 | Televison & Video
I pushed too ******* my screen and now have fine lines o colour and black areas gradually spreading over my screen. My laptop is an Acer Extensa 5635.
afraid you have broken the laptop screen its easilly done, they are straight forward to replace but prices are usually about 45 pounds on ebay for that model, you will have fitting on top unless fitting yourself though, if you are fitting it yourself all you need to do is remove the 4 screws from each corner of the screen and gentle remove the plastic facing around the screen, then remove the 2 screws from each side of the screen then disconnect the cable, put in new one attach cable and seal the laptop back up and that will fix your problem.
Jun 12, 2012 | Acer Extensa Computers & Internet
RE: DELL Inspiron 1300 Hello, Would a 14" screen
NO! it will fit in the opening but it will not have anything holding it in. So while yes it technically will "fit" it wont work as the screen will fall out every time you close it!
Sep 17, 2011 | Dell Inspiron 1300 Notebook
I am looking for a screen to fit my asus x58l laptop...
I hope this might be able to help you, if you are looking for an screen to fit your machine, I would suggest you to purchase the screen from the following online shop:
http://www.laptopscreenshop.com/catalogsearch/result/?q=ASUS+X58L+15.4%22+WXGA+LAPTOP+LCD+SCREEN
Aug 31, 2011 | ASUS Computers & Internet
Ok so here is what happened play by play i was listening to music on my bed with my laptop i fell asleep with the screen shut i woke up an dwent to go turn off my computer and whaen i opened the laptop the...
you have either,
cracked your laptop screen
or
the ribbon cable has come loose,
Either way you will need to take off the front of the laptop screen plastic bezel
remove the screws
detatch old screen,
if the screen is cracked replace the screen
if there is no cracks then check that the ribbon cable didnt come loose
u can put it back in and check the screen works before putting the front bezel and screws back in
If you are not confident ask a laptop repair guy to do it for you
i fixed one last week for a client,
it was £88.70 incuding VAT and special recorded delivery (with insurance)
screen arived next day and took me 1 hour to fit
I charged the lady £45 to fit the screen
So if you want to save money do it yourself
You can find Youtube videos explaining how to do it, thats what i did
I am a PC repair guy, but i had never had to fit a screen before
I had no problems whatsoever fitting it
the hardest part for me was getting the front plastic bezel off and then back on at the end
goodluck hope this helps you please rate me
thanks
Apr 08, 2011 | Computers & Internet
I want to replace my laptop monitor
very easy
im in the proccess of doing one right now
if the screen is cracked it needs replacing, otherwie you might just need to re seat the cables
Simple google the name of your laptop (find the exact model on the back of the machine)
Buy you screen, i just paid £88.70 for a screen which arrived today, that was with VAT and delivery
Simply
Use a flat head scredriver or a knive to pry the front bezel off the laptop screen
This will reveal some screws, take these out and rest the screen on the keyboard, put some kitchen roll or other on the keyboard to rest the screen so it doesnt get damaged
There will be 2 cables, a power cable and a ribbon cable, detach both of these
Simply fit your new screen, attach the 2 cables, re fit the screws and the front bezel
I am charging the lady £45 to fit her screen
So if you can do it yourself youll make a nice saving
If your not comfortable then find a local PC repair service
Goodluck
Apr 05, 2011 | Acer Computers & Internet
Everything is too big
Sounds like the screen resolution has been changed. Right click on the desktop goto Properties -> Settings and slide the Screen Resolution slider to 1024 x 768 then click on Apply. If that works you should see all your icons as you did before, The resolution can be adjusted higher if its more suitable for you. Most 17inch laptops work between 1024 x 768 and 1152 x 864. If that doesn't work let us know! :)
Jan 14, 2009 | Dell Precision M90 Notebook
Laptop 17' samsung need to know if 17' made by lg would fit
no it will not, the screens are oriented very differently from one another. the pins and the wire tapes are placed on different parts. but if you will be modifying the actual case of the laptop screen, then it may fit. but as it is, it will not fit.
Nov 24, 2008 | LG Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
