Dump lcd samsung t240 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
Do a re-tune [auto-tune]. This will bring back all the channels. Refer its user manual for details. Gopakumar Gopalan Google
Posted on Apr 14, 2014
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Samsung t240 - discharging capacitors?
The main 400v capacitor is the one to watch out for. If you carefully handle the power supply board and avoid the area around the power plug you should be good. To properly discharge the capacitor you would need to use a very large resistor and wire to short out the capacitor but if you do it the wrong way you can damage the board beyond repair. Below is a picture of the T240 power supply board with the 400v capacitor circled in red. If you need to get the other capacitors that need to be replaced on the board, which is the most common problem then you can get a parts it here:http://www.ccl-la.com/catalog/product_info.php?products_id=205
I hope this helps,
BuddyMc
Sep 20, 2012 | Samsung SyncMaster T240 24 inch LCD...
The samsung t240 syncmaster when switched on shows Samsung Logo then displays for 2 seconds then goes dark. I can barely see some settings to change but trying to change these has no effect. When I switch...
Is this a laptop?
This a common problem for monitors, especially on laptops. This cause by the inverter board. The inverter boosts voltage to light the screen. When goes bad they go bad they often work for a few seconds. If you look closely you can see the screen but the voltage is not there to get brightness.
Dec 06, 2017 | Samsung SyncMaster T240 Monitor
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
My samsung t240 screen turns black after 2 secs to an almost black screen, could it be a problem with the fuse as the monitor still has power??? plz help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Samsung SyncMaster T240 Monitor
Samsung t240 monitor lost pic
This problem with the T240 (t240M or T240 HD depending on the coutry) monitor on Windows 7 and maybe on Vista
is due to Samsung´s driver witch is not updated to Win 7. You will have to lower your video
resolution to 1600X1024 (higher resolution accepted) be able to use your monitor. Unfortunately it will not work on Full HD mode on Win 7,
until Samsung releases an updated driver for win7.
I had the exact same problem here and found this information together with the samsung people.
As yet they have no idea when the needed update will be available. Hope soon, till then no Full HD resolution for us.
Cheers from Brazil
Mar 04, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
Samsung syncmaster t240 with thin colored stripes on display
Once you have stripes or lines in the screen then the only solution is to get the screen replaced but that would cost just as much or even more then getting a whole new monitor.
Aug 14, 2009 | Samsung SyncMaster T240 Monitor
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
