Question about Senville 18000 BTU Ductless Air Conditioner & Heat Pump
Senville mini split displays a "defrost" symbol????
I bought an 18000 BTU ductless unit and it ran great through the summer. Now it is spring and I have selected the unit to heat mode. Initially when I selected it to heat mode the unit was turned off. The remote was changed to indicate heat mode and then selected to on. The base unit you can hear the fan start up, then after several minutes the head unit fan cuts in and runs warm air for a few seconds then the heat seems to lessen then the the head unit stops with a "defrost" icon displayed on the head unit beside the temperature setting. The base unit continues to run, however the head unit cycles off for a few minutes then on then off again... I can feel that the high and low pressure lines that one is hot while the other is cool. The head unit runs for about 45 sec to a minute then cycles off where the defrost icon displays. I am pretty disappointed that this is such an issue...as stated by others Senville has no webpage for people to write and ask questions in a forum. Might be helpful to scan for what others had to do. Any advice on what to do would be appreciated. S.
    Problem Solver:
  • 14 Answers
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Posted on Apr 13, 2014
Display shows ec and then flashes 7 times
Don't have a answer but my 12000 btu is doing the same thing
May 13, 2016 | Senville 24000 BTU Energy Star Ductless...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Were dose the green wire go to my senville 18000 heat pump indoor unit
The green thermostat wire goes to the G on the terminal strip. If it's not a thermostat wire it is a ground wire Should be grounded to the metal case for safety. It does not affect the operation.
Nov 14, 2014 | Senville 18000 BTU Dual Zone Ductless Air...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Senville 18000 BTU Ductless Air Conditioner & Heat Pump Logo
552 people viewed this question
Top Senville Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Senville Heating and Cooling Expert? Answer questions, earn points and help others
