Question about Sony Reciever Str Vx-550 Vintage No Remote
Sony str-vx550 Bought a Sony STR VX-550. Turns on and display lights up, but no volume. Cannot get it to produce volume from the Aux (with turntable plugged in), or from the tuner. Tried both with headphones and speakers.
  • 15 Answers
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Posted on May 27, 2008
  • 71 Answers
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Posted on Mar 15, 2009
dunnbiker
  • 8546 Answers
SOURCE: how to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Posted on May 17, 2009
videotransmi
  • 105 Answers
SOURCE: when iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Posted on Jul 09, 2009
  • 94 Answers
SOURCE: sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Posted on Sep 22, 2009
How do I connect my turntable to a str de-675 receiver
Take 2 rca wires a white one and a red one. On the back of the receiver, find a source you are not using( md/tape or aux ) connect red to red, white to white Turn on receiver and on the front, push related button( aux ). This should work. Good luck
Feb 10, 2015 | Sony STR-DE675 Receiver
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
I have an older Sony receiver(STR-DE445) ,has no input for a turntable.I recently picked up a Dyanaco pre-amp(PAT-4),much older.. Is it possible to use the pre-amp to hook the turntable to the Sony...
Yup, TT to the PAT-4 Phono In. Any output on the PAT-4 to any Line Level input (like AUX). The PAT-4 will affect the volume UNLESS you use the Tape Output. I'd use theTape Out to reduce the complexity of tandem volume controls.
http://www.blackswampaudio.com/Inventory/Full_Description.php?recordID=108
http://www.blackswampaudio.com/images/Inv/108.2.jpg
Jan 30, 2011 | Sony Audio Players & Recorders
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Oct 19, 2009 | Sony STR-DE435 Receiver
When I hook up the RCA cables from the Phono to minimal volume
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
Apr 30, 2009 | Sony STR-DE598 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
Sony STR-VX550 receiver does not respond correctly to commands from optional Sony RM-S750 remote commander. Remote is working properly and activats all functions on my other STR-VX550. Only on/off command...
If this is a recent occurrence, unplug receiver for 20 minutes. This will reset the receiver. If the remote is programmable, reprogram it for the receiver. If you do these steps and it does not work, you need a different remote.
Aug 22, 2008 | Sony Audio Players & Recorders
Sony STR-VX550 does not obey remote commands from "optional" Sony RM-S750 remote commander. RM-S750 is working properly and communicates all commands to my other STR-VX550. Receiver appears to be...
You appear to have reprogrammed your remote. Remotes can work with other units made by the same company. But the keys will pass out different signals to each unit. You need to find the correct code for your unit.
This could involve selecting a combination of keys on the remote and possibly some controls on the unit. Then entering a numbers on the remote.
It could be that the unit has the option of selecting a remote mode 2 also. So you will need to select it back to one or whatever it is supposed to be.
Jul 09, 2017 | Sony Audio Players & Recorders
Sony str d715
help, my sony str-d715 just made a blue spark. no more text on the front but lights on volume nobb and monitor tape light are working still? did it just clip the amp?
Jan 25, 2008 | Audio Players & Recorders
Sony Reciever Str Vx-550 Vintage No Remote Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
