Question about Jetway 939GT4-SLI-G Motherboard
I want to change the boot order in my jetway motherboard from cd
I want to install win 8
    Genius:
  • 2,432 Answers
Re start your pc then while the pc is boot press control alt delete . then it will go to bios set up . then select first boot set up to cd .
Posted on Apr 13, 2014
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
I have a dell E510, trying to do a fresh install of windows 7, but it wont boot from cd, or usb flash drive. boot order was changed to boot from cd first then usb second. after that failed hit f12 and...
Hello
If this is a win 7 upgrade you need to have xp installed first,then you can install win 7.
If not,then in the boot order change to cd dvd then hdd,if you have two hdd make sure your primary is first.
Last,if you have a xp disc boot from that and do a delete partion and format the hdd.Then try win 7
Apr 04, 2011 | Dell Dimension E510 PC Desktop
I purchased a new motherboard Jetway LGA775.... keyboard and mouse do not work. How do I make them work?
The motherboard does not have the drivers installed and that is why they are not working. If you have the cd's for them, try booting pc with the cd's already installed. They should have auto-detected them. If you have a schematic of the motherboard, check all jumpers to make sure they are set correctly.
Jul 11, 2009 | Jetway MiniQ-450 P4/ 533FSB W/ Remote,...
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
In win set up
Hi!
You need to change the boot "boot from cd" to Boot from HDD"
You do that in the bios
So start the installation again, and when your pc starts to boot, get in to the bios and change the boot sequence to HDD
Good luck
Nic
Mar 04, 2009 | ASUS P4XP-X Motherboard
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Install motherboard drivers for the first time
If you have a genuine copy of XP then it should boot from that and install it. If it's not booting from that you may have to change the boot priority in the bios, the motherboard manual will tell you how to enter the bios and make and save changes.
Are you sure it's not trying to boot from the hard drive.
As for the motherboard drivers they are installed after you put XP on.
If it's not reading the XP CD properly you may have a bad CD or CD Rom.
Mar 13, 2008 | Televison & Video
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
Jetway 939 gt motherboard install
What install disk are you talking about, and sorry ,need to know the error too.
Nov 18, 2007 | Jetway 939GT4-SLI-G Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
99 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
