Question about Bernina Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
I cannot wind cotton onto my bobbin. I think I cannot wind cotton onto my bobbin. I think the clutch is not disengaging properly. the clutch is not disengaging properly. I had the machine serviced but they did not fix this problem. Help!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Posted on Apr 29, 2014
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
SOURCE: Bobbin won't turn
take the top of the machine cover off by removing screws on top plastic cover. Make sure that the rubber ring on the wheel that turns the bobbin threader is making contact with the belt from the flywheel in the back. You may need to see if it turns freely. If not take it off and lubricate it until it frees up and then replace it and the cover.
Posted on Aug 11, 2007
SOURCE: Winding the Bobbin
If you have a top winding bobbin on the right hand side it may be that the winder is seizing up, you must put a drop of oil now and again down the spindle otherwise it goes dry very quickly at high speed.
Posted on Jan 21, 2008
bargainbox
  • 1388 Answers
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Posted on Sep 01, 2009
  • 152 Answers
SOURCE: bobbin won't come off the winding spindle
Your bobbin was basically crushed slightly, to remove it simply take the thread off the bobbin and it will come off very easily.
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
Posted on Oct 12, 2009
Testimonial: "yes,actually that is precisely what I ended up doing, but thank you for the tips as to how to avoid it happening again. It is a great help!!!!"
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
Tip
Winding a bobbin correctly
The heart of sewing is producing a well tensioned seam and achieving this with any sewing machine will be difficult if you don't wind a bobbin smoothly and with even tension onto the thread. If you look at your bobbin and the thread on it looks all lumpy and uneven, then this tip is for you.
Each time you wind a bobbin, whatever sewing machine it is on, it is really important to keep even tension on the thread as it winds onto the bobbin. Many machines will have a little tension disc you take the thread around but your technique is important too.
Usually you take the thread from your spool of cotton on the right, across to the left on the top of the machine and around a tension disc, or through a thread eye, then back to the right to your bobbin winding spindle, if your bobbin has holes in it, then pull the thread tail up through a hole and pop it onto the spindle. Engage the spindle by pushing across against the stop. Now start winding SLOWLY while holding the thread tail up in the air until the core of the bobbin has been covered in fully and your thread has covered up the starting point to hold the beginning tail. Stop winding, and trim the tail off against the bobbin with a pair of snips. Now resume winding at 1/2 to 3/4 speed and do two things, one with each hand. With one hand put tension onto the top of the spool you are winding thread off - use the curve of your scissors handle into the indent on top. And with your other hand, give the thread a nudge as it winds onto the bobbin to ensure you wind fully across the whole bobbin evenly. Watch it carefully to ensure that you get a smooth even wind.
An analagy: if you wind the garden hose onto the hose reel really fast and let it go anywhich way, the hose will kink and wind mostly in the middle then the reel's full and you've still got half the hose to put away. Thread is the same, its been wound onto a spool by a machine in a very precise way; you want the same smooth evenly tensioned winding onto your bobbin so that when you stitch out the seam the thread is consistently fed off the bobbin.
Don't be tempted to wind flat out and just let it take its own path as you won't get good smooth bobbins of thread. And if you let the thread come off the spool at a fast pace the spool may bounce around, causing fluctuations in the tension on the thread. When you stich a seam, the thread will relax unevenly in your seam causing puckers and ho hum stitching.
Simple stuff but it makes a difference!
on Oct 02, 2011 | Sewing Machines
How come spindle is so short to put spool thread on
Is it the spindle for the top thread or is it the spindle to wind the bobbin? The bobbin is very short because it needs to accommodate only the width of the bobbin. Older machines sometimes do not have thread spindles tall enough for the large spools of thread that can be purchased today. I cut a plastic drinking straw into a length long enough to accommodate the thread spool and simply slip the plastic straw over the thread spindle. Voila! A longer spindle!
Sep 04, 2017 | Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
Husqvarna mega quilter
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
How do I load a bobbin?
There should be a small spindle up on top near the wheel (right hand side).
Start winding the thread on by hand a few wraps to hold it in place and put the bobbin on that small spindle, making sure it is going to wind the proper way. To find out what way it will wind you can first (without the bobbin) push the spindle to the right so that it spins when the wheel turns, turn the wheel by hand for this so you can see which way it is spinning the spindle. Is it clockwise or counterclockwise? Then put your bobbin on and push it to the right so that the wheel will turn the spindle as you press the foot pedal. You should have some sort of tension clip on the top left of your machine, it looks something like the top of a big screw or may be a flat hook. Put the threat under that so that it goes directly from the spool to the bobbin, NOT through the needle. As gradually as possible wind the thread onto the bobbin but not too full, most machines will stop filling it when the bobbin is full. If yours does not, stop filling it when there is still about 1/16 th of an inch room left.
Nov 21, 2009 | White Sewing 1866 Mechanical Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
229 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
