Question about Harman Kardon DPR 2005 Receiver
HK DPR 2005 is shutting off by itself after running for about 5 seconds
My HK DPR 2005 is shutting off by itself after running for about 5 seconds. I plugged my phone to the CD input, as I had done many times before, and I must have shorted something out. could this be something easy to fix?
  • 66 Answers
When you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Posted on Apr 19, 2014
4 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: I have a HK
This means it's going into protection mode. If you have speakers hooked up I would try disconnecting all the speakers and see if the problem persists. If so there is an internal problem that would need to be repaired by a professional. Being that this is only a pro logic receiver if you look on craigslist or ebay. You could most likely find a used receiver in your area for much cheaper then the cost of repair. I've seen great receivers for as little as 50-100$ on craigslist.
Thanks,
Lee
Posted on Nov 05, 2010
  • 11800 Answers
SOURCE: My HK DPR 2005 has
This is caused by the instability of the control processor - it just executes commands that noone gave. It's a quite common problem and it's caused by the aging of the filtering capacitors - the parts that are supposed to stabilize the functioning of the other components. The aging of the capacitors is reduced when they are kept powered for longer - the fact that the receiver has been rarely used has accelerated the aging process.
Yes it's quite easy to fix - all you need to do is to replace some of the old capacitors and add some new ones on top of the other. the replacement capacitor are cheap - less than $25 for all of them. The job is very simple but it's time consuming so the labor will be great (over 3 hours) and because of that quite expensive. Shop around for a repair shop that will fix it on the cheap.
In any case it will be cheaper than getting a brand new one - but if you can find a deal don't hesitate to replace it.
Posted on Dec 09, 2010
SOURCE: My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Posted on May 31, 2011
How to connect a Nakamichi CMS-5 Compact Music System with Harman Kardon BDS 277
There's not a lot of info on the web about the specs and sockets on a Nak CMS-5 or the RE-5 reveiver that's part of the system. So some of this is based on the tiny fragment of information you provided.
The HK BDS277 has no outputs, only inputs. So however you decide to connect, the only way that things will work is if sound signals come from the Nak and go to the HK so that the sound comes from the HK speakers.
If the Nak has processor sockets as you have half suggested, then they act as a break point between the NAK pre-amp which does source selection and the Nak power amp that provides the muscle to drive the Nak speakers. Disconnecting the links from Processor Out/Processor In with interrupt the signal flow. You'll then be able to connect Nak Processor Out to one of the line inputs on the HK.
Any sources already connected to the Nak will then have their signals routed to the HK. The Nak speakers will be silent.
I hope this helps.
Oct 19, 2014 | Nakamichi CMS-5 CD Shelf System
I have Nakamichi CMS-5 and cassette deck DR-5. How i configure it to connect with Harman Kardon BDS 277. In CMS-5 there are 4 Jacks that read Processor, What is the purpose of those jacks. Not a singl
I hope this helps you.
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
My denon avr 1803/883 shut off while playing a cd that had only been in for 5 minutes. there have been no changes to the inputs or additions to speakers. atthis time when i turn it on it is on for about 10...
CHECK IC101 AND IC102 THESE ARE THE + AND - 15VOLT REGULATORS. iF THEY ARE OFF BY MORE THEN 3 VOLTS IT WILL SHUT THE UNIT DOWN/IC101 IS THE +15V AND IC102 IS THE -15V IF THESE VOLTAGES ARE GOOD THEN THE UNIT IS GOING IN TO THE PROTECT MODE AND YOU WILL HAVE SHORTED OUTPUT TRANSISTORS. I HOPE THIS HELPS YOU.
Mar 27, 2010 | Denon AVR-883 Receiver
My nokia 6265 turns on but then turns itself off after 5 seconds
there is a software problem. firstly hard format it by pressing *3call buton then press starting button.it will start formating.
Dec 11, 2009 | Nokia 6265i Cellular Phone
Harman Kardon DPR 2005 7.1 back speakers out
Upgraded unit at local electronic store for discount. wanted something with more power anyways. Thank You for
Oct 05, 2008 | Harman Kardon DPR 2005 Receiver
My harmon kardon dpr 2005 shuts off after about 15 minute
Unit may be overheating. Make sure unit has good ventilation or that it is not being overdriven
Apr 21, 2008 | Audio Players & Recorders
RF channel is messed u
Problem is it is a common problem. I have one with the same thing, it appears as though HK discoed the line for a reason and sold them all at half price in Costco.
Mar 02, 2008 | Harman Kardon DPR 2005 Receiver
Harman Kardon DPR 2005 Receiver Logo
165 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
