Question about Harman Kardon DPR 2005 Receiver
My HK receiver runs for a few seconds and shuts down.
My HK DPR 2005 is shutting off by itself after running for about 5 seconds. I plugged my phone to the CD input, as I had done many times before, and I must have shorted something out. could this be something easy to fix?
Duncan
  • 218 Answers
SOURCE: Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
Posted on May 02, 2007
SOURCE: Haron Kardon 3375 Recevier Shut Down Problems
5 amp "slow blow" fuse where power cord connects to amplifier has probably blown. 9 screws holds the cover on, remove them and check fuse.
Posted on Dec 09, 2007
SOURCE: harmon kardon avr 125 shuts down
CHECK YOUR WIRING!!! I have had problems from time to time, generally after re-arranging, and have found speaker wires slightly touching on 1 channel caused my AVR to give similar problems. GOOD LUCK!!!
Posted on Mar 04, 2008
im4um2
  • 77 Answers
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
SOURCE: HK AVR 645 7.1-Receiver Turns off when sound starts to come through
Hello, I didn't end up fixing the Blu-ray issue, but the TV issue was caused by just inverting the positive and negative cable going into my speaker. Odd enough, instead of just not working, it just flipped the entire system off. I can definitely see that that could be the issue, another one I thought of is, at the time I didn't realize that DVI doesn't play audio, only video and I didn't have a optical cable connected. I decided to avoid the hassle, sell the TV and purchased one that has HDMI. Muuuuch better.
Posted on Aug 08, 2008
when you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Apr 13, 2014 | Harman Kardon DPR 2005 Receiver
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
My 2005 equinox cooling fans come on for a few seconds &shut off making engine over heat &OVERHEATING What is the problem?
Should be a relay somewhere in the engine compartment - may be failing. You may be able to switch with another relay to diagnose.
Check your owners manual under fuses and relays.
Jun 23, 2012 | 2005 Chevrolet Equinox
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
May 28, 2009 | 2002 Pontiac Grand Prix
My harmon kardon dpr 2005 shuts off after about 15 minute
Unit may be overheating. Make sure unit has good ventilation or that it is not being overdriven
Apr 21, 2008 | Audio Players & Recorders
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Dec 10, 2006 | Harman Kardon HK 3375 Receiver
Harman Kardon DPR 2005 Receiver Logo
63 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
