Question about Sanyo PLC-XP200L Projector
Sanyo PLC XP200L Reduced light output
The projector seems to be delivering about 4-4.5K ansi lumens although the lamp is switched to full power. Swapping the lamp does not solve the problem. The projector originated in the US. It may have something to do with auto voltage selection etc.
SOURCE: sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Posted on Mar 22, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
SOURCE: Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Posted on Feb 08, 2009
kalamazoo222
  • 285 Answers
SOURCE: how to reset lamp hour of sanyo plc xu 250
This is from the owner's manual:
Posted on Dec 01, 2010
  • 8909 Answers
SOURCE: sanyo plc-sw30 i have a
The uProcessor thinks that it has overheated and is frantically trying to cool down what it thinks is a hot lamp.
This condition has many causes from an exhausted lamp to lamp ballast fault or even a power supply fault or a heat sensor/fan fault.
Posted on Mar 30, 2011
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
How can I tell if the lamp still works? I dont have the projector to text the lamp so I'm wondering if there is any way to tell if it still works.
Because the lamp does not have a filament, you cannot run a standard continuity test either. You really need the correct power supply and ballast to see if it still works. Many old lamps will continue to work although the lumen output will be significantly reduced.
Jun 28, 2010 | Panasonic Projector Lamp for PT-LB50...
No indication power is getting to the unit. no lights, nothing happens when on button pushed. Re:PLC XW200
try using another power cord and make sure that the lamp is replaced,cleaned,and also securly fitted.
May 06, 2010 | Sanyo North America Plcxw200 Xga 2200...
Sanyo xp200l doesnt turn on shutter lamp blinking
replace the lamp and reset the lamp timer.
Oct 18, 2009 | Sanyo PLC-XP200L Projector
Sanyo plc se15 no light output
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XP200L Projector Logo
44 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
