Question about Epson Perfection 1240U Flatbed Scanner
How to attach loose scanner glass
The glass platen of the scanner has become detached and has fallen down. What sort of adhesive or double-sided tape is recommended to attach the glass to the plastic of the scanner body? Bear in mind that the glass is mounted beneath the upper body so the adhesive or tape must be strong enough to support the weight of the glass.
  • 20 Answers
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Posted on Apr 13, 2014
  • MCG65 Apr 13, 2014
    Thanks Colin. That is exactly the sort of thing I was looking for.
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
Reattach backing for side view mirror
Go to your auto part store or body shop and ask for 3M mirror adhesive.
Jan 18, 2014 | 2008 Chevrolet Avalanche LTZ
How to re-attach a "bug" shield
3M double back adhesive tape. Make sure both surfaces are clean and dry.
Mar 15, 2010 | 2002 Honda Odyssey
1995 Saab 190 convertible, the rear windshield is detached at the top and bottom. It there a way to re attach this properly. The strip the window is supposed to be attached to is torn on the outside but is...
I'm not sure if it is exactly the same problem or not. In my case the glass detached/unglued, on both sides, from the strip that is sewn to the top. I used Clear RTV Silicone Adhesive and Sealant made by ProSeal and purchased at Harbor Freight.
Be careful not use acrylics . Even though they will water proof, they become brittle with temperature changes. You want and adhesive that remains flexible.
Good luck.
Nov 09, 2009 | 1995 Saab 900
One of the keys on my acer 5315 have fallen of does any one know how to resemble it again
The key should just clip back onto the board.
If not, there usually is some sort of rubber where the key was. Use a bit of double-sided sticky tape, or better: Blu-Tack (just a little) removable adhesive, and place in/on the rubber on the keyboard. Place the key in place and push down firmly.
If that doesn't resolve it, consider buying a new keyboard (about $20 and must be from same EXACT model) and put in place.
Hope this helps.
Jul 30, 2009 | Acer Aspire 5315 Notebook
Mac wont recognize Mustek A3 1200 Scanner
If you have a photo editing program, see if it can connect to your photo scanner. Look under "File" and then "Import". If there is a "Twain" choice, that should be your scanner.
Jun 24, 2009 | Mustek PARAGON 1200 A3 Pro Flatbed Scanner
Microtek scanner 4800
ohh.. there must be a problem with your scanner dude..
Mar 25, 2008 | Computers & Internet
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Epson Perfection 1240U Flatbed Scanner Logo
399 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
