Question about Irons
Screwdriver to open kenwood steam iron - Irons
3 Suggested Answers
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
  • 2825 Answers
SOURCE: What size of tamper-proof Torx tool I need to open my SS400 Kenwood steam generator iron
I'd get a set, they're inexpensive enough.
Posted on May 18, 2015
My kenwood kbs 11b is not producing steam and stand by light is flashing, what should i do?
the steam holes is plug.
If you have hard water doposit in the line try some cr7
Oct 30, 2010 | Euro-Pro Steam Generator EP8001 Iron
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Have just bought kenwood steam generator iron but there are no instructions with it. the filter light is flashing what do i do
Aug 31, 2009 | Irons
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Sewing needle
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Mar 26, 2009 | Rowenta Irons
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Screwdriver
it is probably a "tamper-proof' Torx head screw and you will need to get a set of tamper-proof Torx bits. Be certain the tamper-proof Torx bit will fit into a bit holder shaft ssmall enough in diameter to fit into any recessed holes that the screws are currently in.
Jul 30, 2008 | Rowenta Steam Generator DG050 Iron
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
