Question about Hayward SAND FILTER, PRO SERIES
Filter sand in pool
When I am run my Kreepy Krauly, sand from the filter comes back into the pool from the return lines.
  • Ron Wilson
    Ron Wilson Apr 13, 2014
    I opened the MultiPort valve, their was sand in that compartment. I vacumed all the sand out, cleaned the 5 spoke gasket (also put the lubricant on it). The Key/stem assembly was a little rough on the bottom. I tried to smooth this off. Reinstalled the value and tried it. Still have sand coming out of the return line. When I have the Kreepy Krauly running it seems to have more sand coming. I do see small bubbles coming out of the return outlet. I also hear a small gergling sound out of the MultiValve. Any suggestions would be appreciated..Ron
  • Hayward Master
  • 1,631 Answers
Greetings,
I am all in as well with the previous assistants (A. Miller) remedy to your problem.
Broken Laterals at the bottom of the filter.
There is no other way sand will enter the pool, bypassing the equipment, unless there is some kind of compromised equipment. As mentioned by A. Miller, the laterals are located at the bottom of the filter, normally about 9 of them approximately 6" long and about 1" in diameter. There are very thin cuts or kerfs in them that are smaller than a grain of #20 Silica Sand. Therefore only water (in theory - clean filtered water) will enter them after being pushed by pressure through the bed of sand to the bottom and entering the collection manifold via the lateral drain assembly.
As A. Miller mentioned, if only one lateral is broken, cracked or compromised, the pressure that is in that filter tank will definitely find that compromise and will "Push" sand right into that lateral, thru the rest of the system and into the pool terminating out the return lines and will collect normally immediately under the return lines. Normally more heavier at the nearest return line to the equipment area.
Although - Another possibility is, if the tank had more sand than required, when you "Backwash" sand could enter into a Multi-port valve (if you have one) and will enter into the return port, and when you turn the valve back to "Filter", you will see sand enter the pool.
Or, another reason could be inclusive of the problem above PLUS a deteriorated filter valve gasket, commonly referred to as a "Spider Gasket". The ports are supposed to be individually sealed and not allow water/debris/sand to pass between these ports, and this gasket keeps them individually compartmentalized.
But a compromised gasket seal could at times create a situation that may lead one to believe that a broken lateral is the culprit.
Removing sand is a chore! Taking the top cover off of the MultiPort valve is easier and a gasket relatively inexpensive.
But if your laterals are compromised, break out the ole shop vac and find that problem.
Good Luck
Posted on Apr 13, 2014
  • 52 Answers
SOURCE: There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Posted on Mar 02, 2009
  • 93 Answers
SOURCE: Dirt comes back thriugh the return when I vacuum
if your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
Posted on Jul 17, 2009
  • 8404 Answers
SOURCE: My swimming pool filter returns dirty water to the
Might you have a broken lateral in the bottom of your filter and what you are seeing is sand coming into the pool?
Do you backwash daily or more often? (You should) Do you have a multi-port vavle or other type?
Im thinking broken lateral. Sucking air in and of itself will not cause dirt to return to the pool.
Whats a lateral? There is a series of pipes in the bottom of the sand with small holes in them. These holes allow water to travel in and out depending on whether you are filtering or back washing ... but not sand. If you have sand, you have a broken pipe.
Open the filter and remove the sand into a bucket to inspect the laterals.
I hope this works for you.
a
Posted on Oct 19, 2009
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
  • 17 Answers
SOURCE: Sand Leaking From Filter into
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Posted on Jun 16, 2011
Pool pump pressure
check to see if filters are dirty if using a sand filter or DE filter put multiport on recirculate which will bypass a dirty filter if sand filter is the problem change sand
Dec 16, 2013 | Universal Kreepy Krauly In-Ground Pool...
Low filter pressure
First, check for debris in the filter and pump strainer baskets. This can commonly cause these pool cleaners to get poor suction. Also, check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
May 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
Cleaner is on bottom of pool
Make sure that the main drain of your pool is closed. It could be causing the Kreepy Krauly to stick. This is often a problem with this type of automatic pool cleaner. Also, check the return line water flow and adjust it if necessary. Hose balance could also cause it to stick on the bottom of the pool so make sure that it is weighted correctly. Finally, check for debris in the pump and filter baskets and also in the flaps of the cleaner. Debris can impact movement in a major way.
Jan 18, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I bought my Bull Shark Kreepy Krauly recently and from the start it lifted up at the end and does not move flat on the surface of the swimming pool. Please assist.
If it has never worked properly, it could be that your pump and filter system are too small for this particular automatic pool cleaner. If you don't feel that this is the case, there a few things that you can check. Make sure that there is not debris in the flapper. It could be causing a loss of suction, making the pool cleaner rise off the floor of the pool. Also, check your water flow coming from your return line. It could be too high. You can adjust it with an eyeball diverter if necessary.
Jan 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly won't move. I've checked the hose for holes and also replaced the vinyl suction cup on the bottom but it won't budge. Doesn't appear that there is much suction. Could it be something...
Yes, it could. Check the filter and pump for debris. This could severely restrict movement in these pool cleaners. Also, check the flaps of the Kreepy Krauly for debris. Also, check to make sure that the main drain and ALL suction lines, except the one the cleaner is attached to, are closed. This might also be why you have a lack of suction. My final suggestions would be to check the return line water flow and make sure that it is strong enough.
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Kreepy crawly keeps stopping but nothing is blocked
With Kreepy Krauly pool cleaners, it is usually something blocked so you have taken the perfect first step in finding your problem. You will also want ensure that the main drain and all suction lines are closed, except for the line to which the Kreepy Krauly is attached. Also, if this is a new purchase, it could be that your pump and filter system are too small to properly propel the cleaner.
Aug 13, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly seems to have good suction, but moves very slow. I usually hear a tic,tic,tic,tic, But, lately it has been tic....tic......tic Very Slow
Try these suggestions to get your automatic pool cleaner working properly:
• Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
• Check for debris in the filter or pump basket.
• Check for debris in Kreepy Krauly’s flapper. Debris may prevent flapper movement or restrict flow.
• Check the hose to ensure there are no leaks.
• Check the vacuum connection. It should be submerged so no air enters the system.
• Check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
Hayward SAND FILTER, PRO SERIES Logo
76 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
