Question about Canon Pixma MX410 All-In-One Printer
Printer wont print
My printer wont print and I keep getting a message on my computer saying that the printer is in a "ERROR STATE"
    Problem Solver:
  • 10 Answers
Then its time to throw your printer in the "ERROR"
Posted on Apr 13, 2014
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
SOURCE: "used ink tank is full"???
OK, Boys and Girls...here finally is the complete answer to the problem of the waste ink tank counter reset for Canon i250 and i350 printers.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
You May Thank Me NOW!!!!
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
I'm not sure how much life this will add to your printer.
Good Luck
Posted on Sep 26, 2008
SOURCE: pixma mp160 error message
Ok, my machine was also showing E3, and would NOT go away. My solution: turn the machine off, feed a piece of thick cardstock into the paper feed.Turn the machine on, let the machine take the paper almost all the way in, then pull it back all the way out against the feed. My E3 disappeared and has not yet returned!! Hope this helps David
Posted on Jan 11, 2009
fotomohamed
  • 321 Answers
SOURCE: paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Posted on Jun 18, 2009
romsky79
  • 822 Answers
SOURCE: I am having a problem with my printer. It is
try to remove the paper case and clean inside specially sensors. then try to print again.
Posted on Aug 15, 2009
I keep getting error state message on my Cannon MG5400 series printer
I checked the cannon web site for solutions to this and found I would need more information... like what is you operation system. Essentially though the site is very helpful and easy to navigate. A tip... in the search window at the top of their site... type in MG5400.
Dec 28, 2014 | Cannon Office Equipment & Supplies
Printer wont print. Keeps saying printer in error state. Control panel says printer ready
check the status of lights on printer then check it on the manual of the printer for that light error
Jul 26, 2011 | Brother HL-2170W Laser Printer
Printer not Printing
well this is the software issue till i can understand. to be sure that it is purely software issue try to copy from your printer itself and see if that is not the printer's fault.
if its not then:
Remove printer's USB cable from your computer
delete the Printer's Icon from your control panel/ system preferences> Printers and faxes/ printers
now uninstall the software of kodak and reinstall the the software from www.kodak.com/go/esp3downloads
after software installs then plug your printer back in and wait untill it get installed on your system
try to print it again and see if you can print
May 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Spp 2020
check your windows settings
and   even if thos are correct maty be the connecting cable is not workinfg
Sep 06, 2008 | Samsung SPP-2020 Thermal Photo Printer
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Error message
does it say an error after "unable to print",what lights? are all inks good?, is there any bits of torn paper inside where head and carriage side up and down?
Oct 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer wont align
Can you complete the alignment through the maintenance tab on the driver via your computer?
Jul 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
Canon Pixma MX410 All-In-One Printer Logo
215 people viewed this question
old marine
old marine
