Question about Fisher and Paykel Refrigerators
Fisher Paykel E521T
My fisher paykel E521T has not been defrosting, and as a result the fan in the freezer is getting blocked up. I've check the freezer seal and its in good order. Could it be the defrosting element? any hints appreciated. I don't know the version number (sorry). Thanks
    Sergeant:
  • 231 Answers
Here is a video which may help you, there are also useful comments
Posted on Apr 13, 2014
5 Suggested Answers
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
SOURCE: water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Posted on May 12, 2011
  • 3 Answers
SOURCE: Fisher Paykel Fridge. Access to fridge fan.
My fridge is 11 years old and recently had the same problem; the freezer was cooling well, but the fridge compartment was not cooling enough. I searched the Web a read most answers. I thought the fan was faulty, but in fact it wasn't (the fridge has got 2 fans, one for each compartment, and they look very similar, the part number on mine was 883340). The whole problem was a build-up of ice in the condenser unit that is at the back of the freezer compartment. What happens is that the ice blocks the passage of air the fan for the fridge compartment. This of course stops the cool air circulating to the fridge compartment. I was able to repair the fridge an it is now working perfectly. This is what I did:
1) Removed everything from the fridge, food, shelves, the lot.
2) I made sure the fan for the fridge compartment was okay, by connecting it to a 9V battery; the fan was okay. (I did this because after reading the posts I was convinced the problem was a dead fan, but you can skip this step if you can hear the fan spinning and think it is okay). To check the fan, remove by pulling the toll plastic cover that fits below the smaller plastic cover with the temperature indicator. This cover is very flexible and flimsy, start pulling from near the bottom and continue along the right side, flexing it as you go along, until it comes free (there is an insulating plastic foam moulding underneath that comes with it). As soon as you remove this cover, you will see the small fan and the plugs. Unplug the fan's connector (it has a small lock you need to press) and wire it to a standard 9 volt battery. CAUTION: observe polarity! The battery positive terminal MUST be connected to the RED wire (or the fan burns!). If the fan is bad, you can remove it very easily by inserting 2 finger inside the white plastic holder, pushing the fan in (the fan is held with 3 very elastic thin silicon bands, that do not break) ,hooking the holder from the inside edge with your fingers and pulling. It will just come out through the slot. (I did this, but then had some problem in getting it back in place. I finally left it in a near flat position, but not quite as flat as it was. Nevertheless it works okay).
3) My fan was good (I wasted a lot of time doing this), so next I shifted my attention to the freezer compartment. I then noticed that the plastic cover at the bottom of the compartment was half dislodged from its proper location, all covered on ice. I removed the cover, breaking the ice that held it with care. This cover is difficult to remove, there is a lot of pushing and pulling, so be prepared and patient; do not break it (mine came out with a small locking leg broken, but it did go back in place without any problems). I then checked the second fan, that is on this cover; it was also okay.
4) As soon as I removed the cover I saw the problem...ice everywhere! I reached for the house hair drier and after about one hour it was all gone. Note that most of the problem ice is behind the condenser (small radiator looking aluminum frame, that should be left alone. Do not move, push or twist it).
5) once all the ice was removed, I the carefully pushed the radiator back in place at the bottom of the compartment (it just fits and had been displaced by the growth of ice), and replaced the plastic cover.
6) and voila! my fridge was again working perfectly. About 3 hours flat.
Posted on Mar 01, 2012
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
E521T
close freezer door, open fridge door and press the mode button
Refrigerators Logo
220 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
