Question about Draytek Vigor 2600VG Wireless Router (v2600vgub)
I lost wireless internet security code number, so that I can not connect wireless internet. How do I connect it wireless?
    President:
  • 1,383 Answers
Access your router with foloowing link
http://192.168.1.1 or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to advaNCED SECURITY OF W IFI THERE YOU SEE wep.
Check encryption it is security code.
If can not able to access router then connect it to computer with ethernet cable .
But make sure dont change anywhere in router.
Posted on Jun 18, 2009
    President:
  • 828 Answers
Reset your wireless router to back in the default settings
    Problem Solver:
  • 5 Answers
All you have to do is reset your wireless. it is not that complecated. And if you don't know how to reset contat me as soon as possible.
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
Can access internet to my laptop via ethernet cable but not wifi through Cisco Linksys router model no SPA2102 as I have lost network security code... tried to find number to call for support but dont...
ok well if you lost your security code then the only way you can connect to your wireless connections again is to have the correct credentials correct Passwords .in your case you lost your Password the only options you have is to reset your router and setup new Password for your wireless . ok lets reset the wireless router now . on the back of your router their is a tiny hole says Reset use needle or a pen to press the button for 40 seconds and release turn off your wireless from the plug and turn it on again . now connect to your wireless and you will not need password to connect Internet.
if you need help with setting up password on your router then email me zana_adil86@hotmail.com
May 02, 2011 | Computers & Internet
I purchased a new laptop,,and when Itried to connect to the internet wirelessly it recognized my router, but asked for security code. I don,t know what my code is.
if you don't know your security code, then you will need to reset the router (Use the reset button on the back) then you should be able to connect wireless unsecured. from that point you can type the default gateway IP address (192.168.1.1) in the address line of internet explorer, this will open the web interface of the router (Leave username blank, admin for password) then you can re-enable wireless security and pick a new code (I recommend an old 10 digit phone number you can easily remember but hard for others to guess)
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
Wireless laptop finds signal, connects to network but no internet
just a thought but may be you can try to remove the WEP/WPA and select the connection mode based on MAC id, hope it was some help
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
I need to find the procedure for at&t 2wire DSL modem wireless connection. I lost the security code and password. The Serial N# is 140811022206 and another # is (2701HG-B) could be the model number. ...
Try going to http://Helpme.att.net your support site or try calling your Internet provided and asked them to create a new username and password for your wireless connection.
If your asking for the username and password that you set in the modem configuration page more likely you are going to reset it and call your Internet service provider for the default username and password for your 2wire modem configuration page.
Jan 04, 2009 | Sprint PCS Merlin S720 Mobile Broadband...
Router Password
That is the wireless security key or network key configured in the wireless settings of the router. Can you tell me the exact model number of the router you have?
Nov 15, 2008 | Dynex DX-E401 Router
Ps3 security code
The security code, that is called network key, is stored inside the router.
Check your router manual, it will tell you how to connect to the router using Internet Explorer.
You put router IP number on Internet explorer bar and open router control panel, then you go into wireless settings, and there you find the key.
Sep 08, 2008 | Sony Playstation 3 (PS3) Console
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
Aug 25, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
I lost the instillation CD and need the wep code
The WEP code is whatever you make it when you set up the wireless connection. If you have lost this key. It is best to use the manual reset located on your wireless router. Will require a small point like a paperclip. Then you will have to access the router and set up the wireless internet over again. Then you can secure it with a new WEP key.
If you need further assistance please ask me.
Thanks,
Lee
Jun 17, 2008 | Belkin (F5D7633UK4A) Wireless Router
Lost code
if you open a internet browser and go to 192.168.1.1, that should take you to your router configuration page. from there check security or wireless security and it will give you your key.
Feb 12, 2008 | Computers & Internet
Draytek Vigor 2600VG Wireless Router (v2600vgub) Logo
263 people viewed this question
Top Draytek Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Draytek Computer and Internet Expert? Answer questions, earn points and help others
