Question about Wahl Health & Beauty
My joytab power button is **** inside the outer case
Can i take the back off
Accelerator/Throttle stuck
most cable outer cases are made up of a spring section so if you bend it there are gaps that open to show the inner cable
CRC or wd-40 are quick fixes but will disperse with time and rain
However if you use lithium grease (CRC product)or spray silicon ans spray along that outer case as you flex it there is every possibility that the problem will be solved There is the possibility that if the machine has seen a lot of use in the accelerator so ot is possible that a groove has worn inside the outer case and that is causing the problem
IT that happens to be the case , get a new cable and before fitting it , if the inner cable can be pulled out , spray the lithium grease down the inside of the outer case and then put the inner cable back in it
Nov 25, 2015 | 2011 Honda Activa
Gateway bios password reset
You'll have to open your case to do it.
1) Shut computer down.
2) Unplug computer power cord - IMPORTANT!
3) Wait a minute or so for all power to be dissipated. (Capacitors hold charge for a while even after shutdown.) This is for your safety, and to keep anything from happening to your computer.
4) Open case. The side is usually held on by 2 or 3 screws. Usually Phillips, could be knurled finger type. Open side by sliding back an inch or so. Then pull side away from case.
5) Look for a small plastic piece, about 1/8" x 1/4" looking from top. It should be on 2 of a set of 3 pins on the motherboard. There should be a label on the motherboard saying "reset" or "PW Reset" or "Password" or "bios reset", depending on which version of motherboard you have.
6) Lift the plastic piece up, noting which 2 of the 3 pins it is on first.
7) Put it on the other end of the set of 3 pins, using the middle pin over. (You are changing from one outer pin to the other outer pin.)
8) Put the power cord back in the power supply. Push the start button. Just a second will be plenty long.
9) Remove the power cord, waiting again for all power to dissipate.
10) Put the plastic piece back on the original 2 pins. Put case back together. Put power cord back, and turn on. The bios password will be removed.
May 25, 2014 | Gateway E-4100 PC Desktop
How can I replace/fix the button spring?
remove the outer case and look for the button spring inside / OR take it to a repair shop .
May 09, 2014 | In Cuisine MM800FS Microwave Oven
Joytab drivers
Joytab is a Google Android 4 (Ice Cream Sandwich) Tablet PC. It does not run Windows 8.
Mar 19, 2014 | Computers & Internet
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
I have taken this xbox apart once before but did not get very far. What type of tools are necessary to repair this type of Xbox 360? I would also like to update the CD/DVD drive on it. Any hints or ti
Most of this can be taken apart with a screwdriver . The case is a little tricky. You will notice from the side...where the case is split, there are tabs on the inside that you need to press. I poked a small screwdriver through the vent holes to press them and get the box apart.
Oct 04, 2012 | Video Game Consoles & Games
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Jun 22, 2008 | Timex Expedition 40141 Wristwatch
Ds lite
WHEN I PUT MY DS ON IT GOES OFF
Jun 14, 2008 | Nintendo DS Lite Console
Health & Beauty Logo
82 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
