0x8007045d 'Hi, I try to install W7 over an existing W8 due to a crash where W8 is unaccessible. The computer is a Fujitsu Lifebook w. a WDC WD5000LPVT disk. The W7 installation program detects two HDD's; #0 on which I can do nothing (internal Fujitsu stuff I guess) and #1 where I have removed, created and format a partition. While chosing that new partition the W7 installation progam returns an error message "Windows can't be isntalled on the chosen partiotion. Error code 0x8007045d". Can I work my way around this error or is the disk corrupt?
    Sergeant:
  • 231 Answers
Unless you are trying to install the 64bit version of Windows 7, it is not compatible with a uefi boot option - this has to be switched in the bios - F2 to access your bios, then look under boot options (I don't have the specific menu for that laptop) what you want is to enable legacy boot options.
Here is some information - select legacy boot options
http://technet.microsoft.com/en-us/library/hh825112.aspx
Posted on Apr 13, 2014
Testimonial: "Sorry, I forgot that piece of information. It actually is a 64 bit version of W7 so as fas as I know it should be doable?"
  • 6 more comments
  • Syllamo Apr 13, 2014
    Try this - but it will delete all partitions and data on the hard drive: At the first screen, hit +. At the elevated command prompt type: diskpart list disk select disk 0 clean
  • Frank R
    Frank R Apr 13, 2014
    Thanks, I'll try that. Accordingly, you do think I have to remove the partitions on disk 0? It is a small disk, only some 25GB, so I thought it would be better installaing on disk 1 which is much larger.
    I wish I could help further but truth is that after 13 years of microsoft support, I no longer install Windows operating systems on my machines, I go for the Linux Mint solution and have had nothing but good times since. That said - 25GB (that is funny) is probably a little small for the install unless you use the other partition for the documents (that is probably a good idea because it shouldn't affect your profile speed).
  • Frank R
    Well, unfortunately Linux is not an option here. Thank's for your help!
    No worries - so install windows into the 25gb partition and then configure windows to use the other partition for user profiles.
    This solution also has the added bonus of separating system from data
  • Frank R
    Right, I've used that config before. Struggling with the removal of disk 0 partitions right now.
    You have to try to go into legacy mode in order to do the install
5 Suggested Answers
lordoflinux
  • 31 Answers
SOURCE: I hit F8, here is the new error message
If this is all you are seeing, then this is not an error. What is happening here is that your computer is loading Safe Mode. This is a way to load Windows operating system without any extra software or programs, using the most basic drivers and software to load. There are a lot of benefits to accessing this mode, especially if you installed a program that stops you from getting into Normal Mode, or you have a virus that does the same. It makes it easy to troubleshoot. Here is a link to a website with a little more info:
http://www.computerhope.com/jargon/s/safemode.htm
If you load your computer normally by not pressing any keys, then you should be fine.
Posted on Mar 27, 2009
p4prince2par
  • 285 Answers
SOURCE: I got this error when installing XP on my old Presario 5000
ur installer disk is not proper
Posted on Jun 03, 2010
thinktech09
  • 177 Answers
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Posted on Jun 11, 2010
  • 345 Answers
SOURCE: Compaq Presario
Make sure you cd with OS is clean and not damaged since this will some times cause issues.This error usually means you computer is not seeing hard drive for some reason.. the partition is not getting on it probably because of bad sectors. i rare situations it will be because of mother board since i have had the same problem. first make sure your hard drive is set as master under pin selection. most times cable select is ok but it might not work always even that it was not changed. make sure ide or sata cable is firmly in or better just remove it and put it back in snug. when you do format do a regular and not quick even that you have done it already since this will attempt to fix bad HD sectors. if this does not work try another hard drive or try this one on another machine if you have one. Hope this helps.
Posted on Aug 09, 2010
Hi is there any way i can upgrade my windows xp to windows 7 for free
I am sorry. There is no legal way to do it for free.
  • The W7 is end-of-sale product. It is hard to buy.
  • It is security risk if you will install some cracked W7. Modified (cracked) unofficial installation sources include trojans or other malware very often.
  • A Windows 8 is good successor. My experience: The W8 is better than W7. Only some details (Start icon) are missing. I have modified the W8 setting, desktop etc. to be similar to W7 and I have become accustomed to W8. You need not use many strange W8 features if you do not like it. I ignore them all too: Loging-in by MS account, Microsoft Store, Bing search engine, Internet Explorer etc.
What do you prefer? A system for free or a Windows?
  • If you insist on Windows, you must pay.
  • If you need good system for free, use a Linux. The Ubuntu is very good option. It is working on all my PC's for years. I install it every time either as a sole system or as a second one. This my answer is written by Firefox running on Ubuntu Linux e.g.
You can follow the links, read about Ubuntu and try it without installation for first time. Requested contributing is not mandatory. Fill $0 or go directly to link: Not now, take me to the download
Ubuntu PC operating system Ubuntu
Feb 12, 2016 | Microsoft Windows XP Professional
Laptop screen crash
try to upgrade the BIOS of your laptop. and if it is not help try to restore your laptop to the good condition date. or try to install new OS and if the problem is the same.
Some of this problem the graphic device of your laptop was damage.
Mar 20, 2013 | Fujitsu LifeBook N6410 Notebook
How to install webcam for fujitsu lifebook a530 ?
Hi'' on a brand new web cameras mostly all brands has an installer driver . as you have it ' unlock deep freeze if it does not have a system lock then go and insert the installer to its DVD Rom then run it to install, then click finish. thanks for using Fixya. . .
Sep 14, 2012 | Fujitsu Lifebook A530 15.6 inch Notebook...
My Lifebook P7230 camera is upside down .
I had the same problem, even after updating drivers, but I found solution.
1. Go to website:
http://www.pc-ap.fujitsu.com/support/drv_lb_vista_p7230.html
2. Download file: Camera Driver (for model with Fujitsu WebCam module) V.1.0.0.1088b
3. Unzip it
4. Open "fujitsu_webcam" folder
5. Run "Setup" and follow instruction
6. When installation is finished restart computer can be required.
7. Next, go to START, and open WebCam in Camera. Check settings. Now, everything should be OK.
Enjoy :)
Apr 02, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
Fujitsu lifebook e780 w7 drivers?
http://ts.fujitsu.com/support/downloads.html
Mar 03, 2011 | Computers & Internet
CRASH FUJITSU LIFEBOOK
hi
Run the pc in safe mode and restore it to a later date. that will solve the problem
Mar 25, 2009 | Fujitsu LifeBook A6020 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Resetting Security Panel Password
Its by virus problem. scan your computer by antivirus with update then try again.
Sep 20, 2008 | Fujitsu LifeBook T4220 Tablet PC
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
