Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
I have the same problem, Turn it on it goes red, then shuts off.
Plus it now has two dots about the size of a dime in the center of the screen. Can it be fixed?
  • 668 Answers
It sounds like the red CRT is shorted and the dots are phosphor burns from the set shutting down too fast without blanking the picture. In most cases if it is a crt that is bad and you have more than one tube that has phosphor burns it is reommended to replace all three CRTs other wise you will have a color imbalance.
Even if the set is less than 5 years old, the cost would be too much to invest being that the newer LCD Projections are comming down in price.
Hope this helps
Skyassoc
Posted on Jun 18, 2009
2 Suggested Answers
  • 668 Answers
SOURCE: Tv turns on red and then turns off.
It sounds like you have a shorted red CRT and it caused phoshor burns on all three CRTs because the blanking circuit could not blank the picture fast enough at time of shut down.
It can be repaired but all three CRTs must be replaced. Cost of doing this is too much for the age of the set. I would invest instead in a LCD projection or LCD flat panel.
Hope this helps,
Skyassoc
Does emachines n214 has a webcam
In short, yes, your laptop should have a built-in webcam. I looked at the specifications sheet on Tom Hardware Hardware News Tests and Reviews for your laptop, and the link is just for your own reference.
The easiest way to tell is to look at the top-center of your laptop display, on the plastic frame, and see if there's a smooth black circle only a little bit smaller than a dime-sized dot.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Jul 21, 2015 | eMachines Computers & Internet
There is a red dot near the center of my Vizio tv screen, what is it?
if just a single tiny dot it is a bad or defective pixel in the front panel-usually there from first time the unit is powered up but from a distance may not be noticed--almost never gets worse or increases in size. Unless set is under warranty do not worry about is as a Panel(entire front screen unit) usually costs more to replace then the entire TV.
Apr 08, 2012 | Televison & Video
Samsung LNT4665F, small red dots on LCD screen when powered on
i've seen this several times. the power supply board is starting to fail. next symptom will be it will not turn on. call 1-800-samsung for nearest service center.
Dec 07, 2009 | Televison & Video
Hope this helps,
Skyassoc
Jun 18, 2009 | Toshiba 57H84 57" Rear Projection...
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Yellow dot about the size of a nickel that appears on the center of the screen. Any help as to what causes this or how to go about correcting?
You probaly have a phosphor burn in the center of the blue picture tube. Solution is to replace the tube or have it rebuilt.
Apr 30, 2009 | Sony KP-57HW40 57" Rear Projection...
I have a tasco pro point plus (red dot Scope) and I need to know the battery size for that scope. The scope is a PDP3CMP Thanks for any help.
The PDP3CMP uses the CR2032 batteries.I had one and gave it to my son who uses it on a huge pistol.I gace him several spare batteries with it.You always need a spare for those things.Good Luck
Mar 05, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
Sony grand wega rear projection tv
You need to re-calibrate the lasers. Refer to your manual.
May 31, 2008 | Televison & Video
Green spot on the middle of screen.
If the spot is perfectly round then most likely you have phosphur burn on 2 of the CRT's. If it uneven then maybe it is a spider who has made his home in there (not uncommon as it is warm and dry which is what they like).As far as cleaning goes, don't use standard glass cleaner as it will damage the screen. Use warm water and a soft towel, or purchase glass and plastic cleaner which is ususally a foam type spray.
Jan 25, 2007 | Zenith A50M91W 50" Rear Projection...
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
