Question about GE 2-9451 4-Line Corded Business Speakerphone
GE Model 2-9450A 4 line phone manual
Red and green light flashing
    Sergeant:
  • 231 Answers
SOURCE:
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
GE 2-9439 Phone i need the manual to store numbers in one out of the 32 speed dial buttons!
1. Press the button you want to program
2. Press the Store button (red light will illuminate)
3. Enter the phone number
4. Press Store again (red light will flash)
5. Press the button you want to program (again)
Jun 03, 2009 | GE 29439GE2 Corded Phone
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Jan 01, 2009 | Dell Inspiron E1505 Notebook
GE 2-9451
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Aug 27, 2008 | GE RCA 4-Line Speakerphone
Light comes on
First, it is normal for the line 1 light to quickly flash once every hour or so while it scans all of the phones. If the light is staying on though then this is a problem.
Look at all of the phones. All will show a RED light except for one that will have a GREEN light lit up for line 1. The green lighted on line 1 means that this is the phone that believes it has the right to use the line. When one phone uses the line all of the others are given a signal through a sub carrier of line one to light up in the color red.
I would suspect that the problem phone is a wall phone unit. This is because the switch on this phone is fighting the weight of the receiver versus gravity. There is not much tolerance in these switches as you will notice if you gently put your finger on the receiver at the top of a wall hanging phone.
If it is a wall phone unit causing this problem you can do 1 of 3 things.
1- you can switch this phone to a desktop so gravity is not working against you but for you.
2 - you can put an ugly looking spacer on the button so it pushes in farther.
3- you can try to perform inside surgery on the phone to adjust the tension of the spring on this button.
Jul 05, 2008 | GE 29488GE2 Corded Phone
Intercom flashing
I didn't fix it myself. We had a phone technician come out to fix the line outside and that must have solved my problem. Thanks
May 27, 2008 | GE Lands Phones
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
GE 2-9451 4-Line Corded Business Speakerphone Logo
208 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
