Question about Health & Beauty
My gemini joytab power button is stuck in how to get it out
It will not charge when button is in
2 Suggested Answers
  • 539 Answers
SOURCE: I need the Full Copy of User manual for Gemini JoyTab 7
Try www.manualowl.com
Posted on Apr 13, 2012
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
Joytab drivers
Joytab is a Google Android 4 (Ice Cream Sandwich) Tablet PC. It does not run Windows 8.
Mar 19, 2014 | Computers & Internet
I want to delete my password from my Gemini tablet
You could do a hard restart but it will wipe all your data.
Turn off tablet.
Hold VolUP and POWER buttons until the Gemini logo appears.
A green robot with a red warning sign will appear.
Press and hold POWER, press VolUP once, release the POWER button. A menu will show on-screen.
With the VolUP and VolDOWN keys you can move up and down. Press POWER to select.
Select Factory Reset.
Then select YES.
Press POWER to restart.
Feb 12, 2014 | Computers & Internet
On startup of my Gemini 9.7" joytab, I get the message "Unfortunately launcher has stopped" when I click 'ok' nothing happens. Has anyone else encountered this?
First,try to reboot the Gemini.If your device still doesn't work prperly,plug in your device via usb to a pc,save all data to the pc,then switch off.
Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  1. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  2. Once completed, press POWER to restart the unit
  3. Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet..
Nov 29, 2013 | Computers & Internet
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
The "cancel" button for the upper section of my maytag gemini gas range no longer works. I used it yesterday and in order to get the oven to turn off, I had to unplug the range from the wall. Help!
Mine was doing the same thing. It was a stuck button under the touch membrane. If you are slightly mechanical you can fix it yourself, by first unpluging the oven from electrical power. Remove the upper panel, by taking 2 screws in back off. Also 2 screws on bottom. You can now tilt the upper control panel down to get at the controller itself. I removed it and unstuck the button. Works fine now.
Aug 09, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Health & Beauty Logo
91 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
