Question about Cell Phones
Disable sim lock - Cell Phones
Sim card puk code n. 8264084361
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
It may not work in all phones, but with standard its working ;)
Feb 14, 2012 | Cell Phones
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
on Jan 21, 2010 | Cell Phones
Cant disable simlock code on a samsung e250.
Hi Use the following code
#7465625*746*Code# ( Disables SIM lock)*7465625*746*Code# ( Enables SIM lock)
Use this code on your phone to disable/enable SIM Lock on E250
Jun 21, 2011 | Computers & Internet
Mobile phone unlocking codes
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Jun 08, 2010 | Cell Phones
Disable Sim Lock.
This can be fixed by-
typing: *2767*3855#(star 2767 star 3855 hash)
NB all files,photos etc on the phone will be lost
Aug 21, 2009 | Samsung J700 Cellular Phone
I have a sim lock problem
Can't tell you if any of this will work..but it's worth a try until you find something better...good luck!
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
May 03, 2009 | Cell Phones
Need unlocking code of Samsung SCH- w339
hi i am using rel connection can i buy sch-w339 and use the phone for rel connection with unlocking code given by u
Dec 31, 2008 | Cell Phones
Need unlock code for my samsung vodafone
Try this it work for me
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam!
I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this!
I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI).
Check Versions of h/w s/w f/w:
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
Locks:
*#7465625# = Check Locks
*7465625*638*Code# = Enables Network Lock
#7465625*638*Code# = Disables Network Lock
*7465625*782*Code# = Enables Subset Lock
#7465625*782*Code# = Disables Subset Lock
*7465625*77*Code# = Enables SP Lock
#7465625*77*Code# = Disables SP Lock
*7465625*27*Code# = Enables CP Lock
#7465625*27*Code# = Disables CP Lock
*7465625*746*Code# = Enables SIM Lock
#7465625*746*Code# = Disables SIM Lock
*7465625*28638# = Auto Network Lock ON
#7465625*28638# = Auto Network Lock OFF
*7465625*28782# = Auto Subset Lock ON
#7465625*28782# = Auto Subset Lock OFF
*7465625*2877# = Auto SP Lock ON
#7465625*2877# = Auto SP Lock OFF
*7465625*2827# = Auto CP Lock ON
#7465625*2827# = Auto CP Lock OFF
*7465625*28746# = Auto SIM Lock ON
#7465625*28746# = Auto SIM Lock OFF
May 03, 2008 | Lands Phones
Samsung e900 **sim lock**????
Try:
#7465625*746*
Jan 02, 2008 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
