Question about PaceMaster Exercise & Fitness
Walking belt has shifted to one side, How do i adjust it back
5 Suggested Answers
  • 11 Answers
SOURCE: Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Posted on Feb 09, 2011
  • 146 Answers
SOURCE: The walking belt on my
if it is moving to the right you must tighten the right side of the rear roller
you are doing wrong side
Posted on Mar 29, 2011
AJIN G
  • 6694 Answers
SOURCE: When walking without holding onto
hi,
To adjust the treadmill belt just watch the following video. It will help you for the same.
ok
Posted on Jul 29, 2011
ercupa190
  • 12223 Answers
SOURCE: walking belt jammed under adjustment guide
see the videos and execute with common sense.
God bless you
Posted on Sep 17, 2012
How do I adjust the belt on my TX40sportcraft threadmill
Set the speed on the treadmill at 2 MPH, If the
walking belt has shifted to the left, use the hex
key to turn the left idler roller screw located on rear
of walking deck clockwise 1/4 of a turn; if the walking
belt has shifted to the right, turn the left idler roller
screw clockwise 1/4 of a turn. Be careful not to
overtighten the walking belt. Always wait to see if the
belt moves as your turning the screws. Take your time
in adjusting belt.
Mar 02, 2015 | Exercise & Fitness
How to adjust treadmill belt
Whet taking off the rear cover on a Trojan treadmill. there is 2 threaded bars with nuts on them. you can adjust there. be sure to adjust them same turns per side or you may have problems with imbalanced belt
Feb 26, 2015 | Exercise & Fitness
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Sep 30, 2010 | Nordic Track NordicTrack Treadmill, A2550
My belt is over to one side to much is there and easy way to get it back in the middle
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Jul 16, 2010 | Proform Quick Burn Pro Treadmill with 12...
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 14, 2010 | Nordic Track NordicTrack A2750 PRO...
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
The walking belt slips to the left when walking
There are two allen bolts (one on each side) at the end of the machine. These bolts adjust the tension on the belt. If they are not adjusted evenly the beft will gradually shift of the more loose side.
Sep 29, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Walking belt folds
It sounds like one of the adjusted bolts or endcaps that adjusts the walk belt is broken,look at the bolts where you adjust and see if the side the belt is shifting to is broken.It may have ruined the belt also but you wont be able to tell till you correct the tracking problem.
Jul 18, 2009 | Proform Sport 1000 Folding Treadmill...
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Jul 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top PaceMaster Exercise & Fitness Experts
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Electro Med Services...
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
