IPazzport ir commander not working
Hello, I have been using this remote control as a keyboard, mouse and IR commander with my Android TV Box with no problems for a while. (http://ipazzport.com/manual/KP-810-19R%E8%8B%B1%E6%96%87.pdf) In the infra-red commander, I managed to set a code that worked fine with my Android TV box, after configuring some files on it. The problem was that not every key was working, so I tried to type some undocumented codes in it (2000, 1999, 1998, 2222 ...) to see what happened. The result was that the IR stopped working. The commander is working, as the red light on goes on when you press a key but the IR LED is not going on anymore. I watched the IR LED with a camera, but no success. It is always off. I wonder if there is a way to get IR working back. QWERTY keyboard and mouse are working fine, by the way.
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
there is no "code search" button on the RCR3273???? can anybody help?
Posted on Aug 31, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 374 Answers
SOURCE: IR remote 103781- Looking for control code for the INSIGNA TV
If you have tried locating your tv type in the back of the manual that came with the receiver and can not locate it then chances are that the remote does not ssupport your TV. You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Posted on Jan 28, 2009
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
  • 10 Answers
SOURCE: URC-9910 remote: The RF part for this remote stopped working.
If your remote RF was working when new, works correctly when it is pointed directly at the RF command center, but not from a different location, I suggest you check for CFL (compact fluorescent lights).
It is a know issue that certain CFL bulbs produce RF frequencies that may interfere with remote controls.
Also from the owner's manual.......
Optimizing IR/RF Command Center Reception
Here are some adjustment tips for optimizing the operation of your
IR/RF Command Center:
• Aim the URC-9910 remote control toward the room where the
IR/RF Command Center is located.
• Do not position the IR/RF Command Center near metal objects,
such as heat ducts.Metal can absorb RF signals.
• Make sure the batteries in the URC-9910 remote control are fully
charged.Try replacing them if you are not sure (see Installing
Batteries
on page 4).Weak batteries will affect the single range.
• Make sure that the URC-9910 remote control is not being affected
by other RF transmissions (e.g., garage door openers, cordless
telephones, etc.).
NOTE: The tests for range limits of the URC-9910 remote control and the
IR/RF Command Center were conducted in open-air distance tests.Actual
signal distance will be based on the construction of the building the unit is
being used in, as well as other factors, such as outside interference.
Also as suggested, you may have to move the RF command center to another location.
If all else fails, your command center may be faulty, and have to be repaired or replaced.
An auction site may be the only replacement option for this discontinued remote.
Best wishes, Greg
Posted on Sep 03, 2009
Have a ZTE android phone ,can it be used as a
It depends on if your phone has IR capabiltily. My LG Volt has this feature and I can control my tv with my phone, or if you have a cable box. Just google the model of your phone along with IR feature next to it.
Oct 16, 2014 | Android Cell Phones
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Why want the remote recognize my directv HR22 remote
Hi. A lot of DirecTV remotes actually use UHF, which is a form of RF. The Harmony remote can only send and capture IR (infrared) commands. Make sure you have your DirecTV device set to receive IR, and if you have an IR remote, or can set your remote to IR, then it will work.
Dec 04, 2009 | Logitech Harmony One LCD Touchscreen...
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
Remote
The IR "bug" provided with the Bose 18/28/38/48 models is an IR emitter which sends out IR control codes to another component. The system is designed to have the Bose remote control be used to control the TV and the dish box. The Bose media center has a strong IR blaster in the front which will flood your room with the IR codes to control your TV or Dish box. The TV sensing device must be placed at a location on the TV where specific voltages can be detected. The location will vary depending on display type you have - plasma, LCD, tube or rear projection.
Dec 20, 2007 | Bose Lifestyle 48 System
TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Mar 02, 2007 | Toshiba 34HF81 34" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
