Dell Diamond Black 15.6" Inspiron N5110 Laptop PC with Intel Core i3- Logo
b
bigdady90 Posted on Apr 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop wifi my wifi conect correctly(use it on my phone),but i can`t use it on laptop.i cant`turn it on or of.i see the onten logo on the taskbar
AJ ZONE LK
Level 2:
Sergeant:
  • Expert 182 Answers
  • Posted on Apr 13, 2014
AJ ZONE LK
Expert
Level 2:
Sergeant:
Answers
182
Questions
0
Helped
6877
Points
508
Please find on your laptop, there must be a hardware switch on around your laptop. please on it, and try.
How to turn on wifi on a dell latitude e6500 that does not have a wifi button
1. Press FN + (function key with radio icon on it like F8)
2. If you runnning Windows 7 you can press WinLogo + X and turn on your WiFi. If you running Windows 8.1, click Network icon on taskbar then turn on your WiFi from there.
Make sure you have the right driver installed.
Can not find wireless
1) Boot into BIOS to check if you have accidentally turned wifi function off.
2) Check if you have deactivated your wifi (by accident), because you pressed the switch which turns the wifi off (or Fnc+ F...).
3) download the latest wireless driver (use a free driver updater software which will do the trick for you... I have been using slimdrivers free, but there are a lot more out there...)
My Ematic 7 4g wifi ebook reader can't conect to
just go to network setting and turn ON WiFi first, then make a search for the availebel networks
The wifi is turned on but there is no wifi icon at the bottom panel of my netbook. i cannot locate the connection management settings.
in control panel go to network settings you will find it in there right click on the wifi connection and go to properties, click the check for show when connected in taskbar then that icon will be on your taskbar at the bottom
I cant conect in WIFI with my samsung GT-S5233W what can I do Help me PLZZzz
Take you phone and laptop to your providers store and have them walk you through, in saying this I am assuming that your phone serves as a hot spot, correct?
Wicked Angel
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
Cant switch on wi-fi what key function is required
Look for the FN key and another key with a Wifi looking symbol on (three lines normally).
Press the FN key and then the second key.
This should turn on the Wifi or launch an application enableing you to manage the conectivity.
1helpful
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
2helpful
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
