Question about JVC Audio Players & Recorders
Jvc kd-321 cd won't play
The radio works but if i put a cd in it says DISC but then I get an error message something like Y0000 A0. Any ideas how to fix this?
    Sergeant:
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 182 Answers
Clean the cd disk drive and see, if it remains the same u need to reprogram the drivers. if u are expert in programming microcontrollers.
Posted on Apr 13, 2014
Testimonial: "Hi,thanks for your suggestion. I'vemanaged to sort the problem out now by pressing the reset but on the installed unit"
  • 3422 Answers
SOURCE: Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on May 01, 2008
kibbs
  • 234 Answers
SOURCE: JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Posted on Jul 01, 2008
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: CD's in Changer won't play
When it is broke it will do that, I mean need to buy another if it does it with all discs. It may not be reading anymoree and therefore says the message you get. Try to load from the my computer as well as desk top and see if anything works. Do you have the number to the company??
Posted on Dec 22, 2009
  • 1039 Answers
SOURCE: I just purchased a JVC KD-S16 CD Player and I can't install it.
Get an adaptor wiring harness. It plugs directly into the plug in the truck. The wires are all labeled and you won't have to hack up the wiring in the truck. You can get the adaptor whereever they sell car stereos.
Posted on Apr 01, 2010
Testimonial: "Thanks much, only added more stress after the first one got stolen to get home with the new one and couldn't attach it. Very helpful indeed."
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
MY UNIT WONT PLAY CD'S
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
JVC kd-dv5000 not playing cd or dvd
try to clean the laser or the main board in it is broke somewhere
May 16, 2009 | JVC KD-DV5000 Car DVD Player
Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Jan 09, 2009 | JVC KD-G322 CD Player
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
JVC KD G 322 cd car reader problem
One of the way to reset it is disconnect the battery and wait for ten second and then reconnect it. Hope it will help.
Feb 28, 2008 | Car Audio & Video
Kd-g322 error code query
I unpluged all the wires for one more time and it works again!!!
I think the problem is that one or some wires are damaged because they are pressed between the unit and its case. I also shaked them up and down and for now, it is ok. Try it!!
If this works for more than one day, I' ll let you know...
Jan 03, 2008 | Car Audio & Video
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
Dec 29, 2007 | JVC KD-S680 CD Player
CD,s will not play
Read the Manual on Page 2 or get it from:
http://de.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-G321
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dirk
Dec 28, 2007 | JVC KD-G421 CD Player
102 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
